Old 06-24-2014, 10:28 PM
drone_pilot drone_pilot is offline
Default Aileron Trim
I have the manual aileron trim that came with my kit. Is it really needed/worth installing? I'm going Dynon Skyview with autopilot. Not sure if it would substitute for aileron trim.
Your thoughts?
Ben
RV-7A Tip Up Airworthy on 12/20/2016
RV-10 Emp 95% complete - sold
RV-14A Empennage Done waiting on front fuse kit to show up.
Old 06-24-2014, 10:50 PM
jimgreen jimgreen is offline
Simple to install. A bit of fiddling to get the friction block adjusted, but very useful.
You are not going to fly with the autopilot on all the time.
I wouldn't be without mine. Might check out an electric trim if I build again (which my wife tells me is never going to happen)
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 06-25-2014, 04:36 AM
Vern's Avatar
Vern Vern is offline
Default Aileron trim
Yes- you will use it.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-25-2014, 05:59 AM
rzbill's Avatar
rzbill rzbill is offline
Both my previous and current autopilots exhibit repetitive roll correction if I do not use aileron trim to compensate for fuel burn. (usually 30, 60 , 60 etc) Its like riding on a bad concrete slab highway or a dripping faucet.
I think you would prefer to have the aileron trim.
Bill Pendergrass
ME/AE '82
Old 06-25-2014, 06:26 PM
So does the electronic aileron trim gain you any advantages over the manual trim?......other than another cool button on the stick grip?
Ben
Old 06-25-2014, 06:59 PM
edbooth edbooth is offline
I have had both, and definately like the electric with button on the stick the best. Makes trimming easy and painless.
Old 06-25-2014, 07:07 PM
spark68 spark68 is offline
Default electric aileron trim
Did you connect the electric trim to a tab, or to the "spring" thing?
Mark Curley
RV-6 (under construction)
dues paid 2020
Old 06-25-2014, 07:16 PM
RV7ator RV7ator is offline
Put it in. You will find it highly useful. Also, autopilots do not like out-of-trim conditions; they twitch. Attach to the springs per the plans. The one bad thing about Van's design is that position is held by friction (unless you use the electric motor). Trim position can move with vibration, and tightening the grip force requires removing the seat pans. I've used a pin through the trim handle into an arc of drilled holes for mechanical stops.
John Siebold
Old 06-26-2014, 03:27 PM
You just connect an electric servo to operate the trim springs instead of the the ugly lever between the seats. Works great especially with the roll and pitch operated from buttons on the stick.
Old 06-28-2014, 05:01 PM
As always, thanks everyone for the advice!!
Ben
