Old 06-24-2014, 06:04 PM
comfortcat's Avatar
comfortcat comfortcat is offline
Default Where does OAT temp probe go?
Wow. a duplicate entry. I need to read more carefully.
Thanks Bruce.
CC
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 06-24-2014, 10:04 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
The builder of my RV-6 put the OAT probe in the NACA vent inlet on the right side of the fuselage just behind the engine cowl. Bad location totally. I can start the engine and watch the OAT gauge climb 10+ degrees as the engine warms up even before I let off the brakes to taxi.
One of these days whenever I get a round tuit, I'm going to relocate the probe to the underside of the starboard wing next to the inspection cover.
Neal Howard
Airplaneless once again...
Old 06-24-2014, 10:10 PM
Greg Arehart's Avatar
Mine is under the horiz stab, right side.
Greg Arehart
N 7965A
Old 06-24-2014, 11:50 PM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
I placed mine in the wing NACA duct and works perfectly.
Bob Ellis
www.rv-8.co.uk
G-JBTR Having a ball flying this wonderful machine
Donation July 2016
Old 06-25-2014, 06:19 AM
rleffler's Avatar
rleffler rleffler is offline
I put them on my RV-10 next to the first access panel under each wing. Yes, I have two. Even though they are about twenty inches away from the fuselage, they seldom agree on the temp. Usually there is a 1-2 degree difference. I'm assuming that is just exhaust heat migrating to one side of the other.\
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-25-2014, 07:43 AM
mikehoover's Avatar
mikehoover mikehoover is offline
I had moved my pitot outboard a couple of bays so I used Vans original pitot predrilled hole in my left wing to mount the OAT probe. Seems to be working great.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-25-2014, 08:23 AM
Super Moderator
Default TAS calculations
Putting hte temp probes anywhere in the fuselage flow will give higher than normal temps due to the heat coming off of the front of the airplane, not just the exhaust heat.
I get a kick out of the temp probes in the fuselage NACA ducts and the pilots talking about their TAS and how fast they are.
I put mine out on the outboard wing inspection panels. Much different readings, and more accurate TAS readings as confirmed by flying a GPS triangle.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 06-25-2014, 09:46 AM
RV7AV8R's Avatar
RV7AV8R RV7AV8R is offline
Default Probe problem
I tested these probes and they are sensitive to the temperature of the mounting base as well as the probe tip. They basically integrate the average temperature of the whole probe and base. So if you put it in the NACA vent you need to insulate the base inside the aircraft so it is not warmed with cockpit heat. I did this with generous gobs of RTV and it seems to work ok.
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
Old 06-25-2014, 08:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I think real simple - an OAT shoudl be exposed to ambient outside air (uninfluenced by engine heat) and out of the. We've got one in the under-wing NACA scoop (RV-8), one just outboard of the underwing inspection panel (RV-3), and one on the tail inspection plate (RV-6), under the Horizontal tail. All work fine.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-26-2014, 02:30 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default OTOH
this goes to show what a terrible location the plans show for a cooling air inlet on the -6. Nothing like sucking air into the cockpit that's a good 10 degrees F warmer than what should be available at altitude for cooling occupants and avionics. If I'd known this 20 years ago, my OAT and NACA vents would BOTH be in a different location!
-Stormy
