  #31
Old 06-24-2014, 08:21 AM
Dave62 Dave62 is offline
Two 90 fittings in fuel line from pump to spider. These will certainly cause the possible vapor lock condition .
Dave (Swift Driver)
Old 06-24-2014, 09:21 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Mel View Post
While it is the duty of the DAR to only make sure that the aircraft meets regulations, He/she may also deny airworthiness certificate issuance for anything he/she feels is unsafe.
I think most DARs go that extra mile to give the aircraft a thorough inspection, informing the applicant of questionable practices.
I know that I will not sign off on anything I'm not comfortable with, and I think my clients appreciate that.
Originally Posted by bill@fusion4.net View Post
I don't think it is futile. Yes there are some that are not built to quality standards, but from looking at most builders projects that I have seen, I think the majority of builders do try to build the best plane they can.
A quality pre-buy is extra important on an experimental.
I wish this forum had a simple "Like" button!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-24-2014, 09:32 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Dave (Swift Driver)
I believe the 90 degree fitting at the spider end is an approved Lycoming part.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2014, 09:41 AM
N941WR's Avatar
Yes, but laying the fuel line just above the #3 cylinder is bad news.
Bill R.
SC86 - Easley, SC
Low Pass's Avatar
Low Pass Low Pass is online now
Dave (Swift Driver)
How? By becoming heat sinks?
Originally Posted by N941WR View Post
Yes, but the laying just above the #3 cylinder is bad news.
Why??
I see some issues here, but not as many as all this "someone's gonna spontaneously combust" indignation warrants. I've seen rental planes with similar conditions under the cowl.
Old 06-24-2014, 09:58 AM
JonJay's Avatar
JonJay JonJay is offline
Why??
There is a difference between "poor craftsmanship" and dangerous practices. I have to agree with you, however, I would not accept it.
Examples - Why isn't the "spider" in it's "normal" location between #1 and #3 cylinders? You could easily solve the unnecessary long fuel line run and clean up the injector lines.
Tie wraps on engine mounts? Still debatable. I apply a few wraps of silicon tape around the mount, but still use tie wraps.
Inter-cylinder baffles? Stupid enough to put them on the top side in a top pressure plenum, big alarm bells go off about the rest of the build.....
I could go on.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-24-2014, 10:04 AM
Low Pass's Avatar
I could go on.
Yep. Guess all the righteous indignation struck me a little wrong. Especially since the guy asked for and received help correcting several of these issues.
Old 06-24-2014, 10:13 AM
krw5927 krw5927 is offline
Let's keep in mind that these issues DID in fact add up to what must be considered a "dangerous practice". When the fan stops turning simply because the electric pump is switched off, that is a very dangerous situation.
Kurt W.
RV9A
FLYING!!!
Old 06-24-2014, 10:29 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Question...........
So, how many hours has this plane flown before your friend bought it???
Obviously there is empirical evidence that some of the dire warnings so far may be just a bit pessimistic.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-24-2014, 10:57 AM
N941WR's Avatar
No idea, I didn't ask. All I did was help arrange for him to get these issues corrected, which he did. He reported back that the plane is now operating as expected.
These pictures were not posted to flame anyone or trash a guy's purchase but as a learning tool for those who are still building.
If someone has a good, clean installation, can you send me your pictures and I'll post them anonymously as a comparison for best practices. (I have a carb, otherwise I would post my pictures.)
Bill R.
SC86 - Easley, SC
