Old 06-17-2014, 11:20 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default Tail wheel bushing
Has anyone ever replaced a tail wheel bushing on the RV-8? Mine is worn and getting sloppy. I called Vans and they sell the bushing but the guy on the phone had no idea how to replace it nor did he know anyone who has ever done it.
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 06-17-2014, 11:43 AM
cjhammes's Avatar
cjhammes cjhammes is offline
I've never done one but like everything else, I am sure it's possible to replace and hopefully others will chime in on "how to". Might want to consider how much life is left on your existing tailwheel rubber. Also, what is your time worth? $35 gets you a brand new wheel & bushing, replaced in a few minutes.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 06-17-2014, 11:51 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I think he is talking about the shaft bushing not the wheel. Vince can take care of you.
https://www.flyboyaccessories.com/
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 06-17-2014, 01:02 PM
cjhammes's Avatar
A ha, that makes sense.
Charlie Hammes
RV-8, N525RV Flying
Old 06-18-2014, 02:17 PM
Default Mounting socket bushing
I have looked on flyboy and the whole end is called a mounting socket. I believe there is a bushing in the mounting socket and that's what i want to replace. I'll get a good look tonight because I am taking it off for a new rocket link and tie down ring.
RV-8 - N861MM
Wilmington, DE
Old 06-18-2014, 06:42 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Matt,
Yes, there is a bushing inside the mounting socket. It is replaceable.
You can find the proper bronze bushings online, or at any good bearing supply store.
We use a better (well, more expensive and easier to work with anyway!) plastic type bushing, but the two aren't interchangeable due to the different flange thickness on the bottom.
It's not a dreadfully difficult job, but you may need a Dremel tool and a sharp chisel to get the old one out. The Van's sockets usually have a steel flange on the top that prevents simply pressing them out. (YMMV!)
Once you get the old one out, just press the new one in. The only hard part is machining the little groove where the locking pin travels. It can be done with a 5/8" end mill or just carefully use your Dremel cut off wheel.
Hint: take a photo of the whole shebang before starting for reference.
Or we can do it for you if you like. We don't have a set price. Just time, materials, and shipping. Each case varies.
Another hint: if the two AN3 bolt holes are egged out, just replace the whole thing with a new one.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 06-20-2014, 12:27 PM
Thanks Vince
RV-8 - N861MM
Wilmington, DE
