Old 06-04-2014, 12:31 PM
Toobuilder's Avatar
I also changed the bellcrank geometry since I had it out and on the bench. I took 1/2 inch off the output arm to help the leverage a little.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-05-2014, 11:31 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Sorry this took a few days for us to notice. We don't stick our noses in the autopilot section as often as we should.
We do have some reports of trim indications not being as accurate as they should. Unfortunately, this isn't user adjustable. However, the good news is that we have been testing an updated trim detection algorithm, which seems to work very well, and should fix this issue with a simple software update. We expect to have this update in the next software version.
So for now, if you are having the issue, all we can tell you is to ignore the alerts for now. It's not indicative of any broken hardware.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 06-06-2014, 07:37 AM
vlittle's Avatar
vlittle vlittle is offline
...thanks, we thought it was our fault.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 06-06-2014, 08:48 AM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Thanks Dynon. As always you are on top of it. I look forward to the update.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 06-06-2014, 10:29 AM
Slowpoke Slowpoke is offline
Mike,
Thanks for bring this issue up, as you know I am having the same issues. I look forward to Dynon's software update!!
Adam/Dana Pontious
58 Bellanca Cruisemaster 7699B (sold)
56 Cessna 172 5016A
2001 Rocket - 584JH
RV-10 - building
1CL2 Pontious airport
Old 06-06-2014, 04:17 PM
gator gator is offline
Default Dynon update
Will the update be for the 100 series as well as skyview?
Old 06-06-2014, 05:00 PM
The release we are working on currently is for SkyView only, in order to see if it is an effective improvement. If it works, we will discuss upgrading D10/D100 products.
Dynon Avionics
425-402-0433
Old 06-13-2014, 12:49 PM
Default 10.2 Beta now out
For those of you with a SkyView and are getting inappropriate NOSE UP or NOSE DOWN indications, we have a public beta to test a fix for this.
http://dynonavionics.com/cgi-bin/yab...1402684755/0#0
Dynon Avionics
425-402-0433
Old 06-13-2014, 01:02 PM
Default Great!
Got it. I'll fly it some this weekend.
Thank you!
Old 06-30-2014, 08:56 AM
I flew a two hour round trip yesterday using the new AP program. Testing the results I found the pitch in perfect trim each time I disengaged the AP.
But it seems now that the altitude struggles to hold steady. I was cruising high in smooth air but several times a small bump would cause the pitch to hunt, up and down about 5 cycles 50 feet or so before settling. Also when I dialed in an altitude change either up or down it would overshoot the 500FPM then overshoot the new altitude starting the hunt again. Before this new program the pitch was rock steady.
Do you recommend any setting changes, or other thoughts?
