Old 06-02-2014, 03:07 PM
704CH's Avatar
704CH 704CH is offline
Default GTN-650 problem
Hey Guys,
I am having a really funny thing happen to my GTN-650. Not sure if others have seen it. For a while now that the weather is getting warmer on taxi out to the runway I would always loose GPS for about 30 seconds. Didn't think much about it, but one day I was taxiing without my headset on.
The GTN Fan Kicked on and boom, lost GPS. So it has been happening with the warmer temps, when the fan kicks on I loose GPS for a short time.
This seems really scary to me for a TSO'd IFR GPS, any thoughts on this problem? Has this happened to others?
Thx
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
Old 06-02-2014, 05:29 PM
Toobuilder's Avatar
I have noticed the fan kicking on a lot more lately, but I have yet to see it take out the GPS signal.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-02-2014, 07:48 PM
Brantel's Avatar
Brantel Brantel is offline
Never noticed any issues with the fan and GPS signal.
I would check your antenna, antenna connections, antenna location etc.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-03-2014, 05:23 AM
rotorbailey's Avatar
rotorbailey rotorbailey is offline
I've had the same issue twice inflight, in an R44 helicopter. Didn't think of heat, but that could well explain it.
Old 06-03-2014, 05:47 AM
MarkW's Avatar
MarkW MarkW is offline
I believe there have been other conversations about the antenna getting hot and loosing reception. Funny that it happens for you at the same time as the fan.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 06-03-2014, 06:28 AM
sailvi767 sailvi767 is offline
I wonder if the motor on the fan is creating interference with the GPS signal. How far is the antenna from the fan? Turning on the AFS 4500 near our 696 reduces signal strength in half. It does not take much EMI to disrupt a GPS signal.
George
Old 06-03-2014, 07:23 AM
Toobuilder's Avatar
In addition to the antenna placement, do you have the specified antenna cable length, and is it coiled up under the boot cowl?
As a point of reference, my antenna is on my canopy, right at my shoulder. The cable snakes around a little bit in an attempt to use up the excess length, but it isn't coiled on itself anywhere.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 06-03-2014, 01:05 PM
Gash's Avatar
Gash Gash is offline
My antenna is firewall forward under the cowl on a shelf next to my Dynon antenna. The Dynon GPS has never lost a signal, but the Garmin occasionally loses lock and takes a minute or two to re acquire. I never considered temperature as a cause. Is there something in writing from Garmin on this topic??
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 06-03-2014, 01:33 PM
Toobuilder's Avatar
The TSO requires something like a 60 inch minimum (don't quote me) antenna lead, AND a 3 sq ft ground plane. I just ran across the ground plane requirement in the installation manual the other night. With so many roll bar and engine mounted GPS antenna's (no ground plane), I had not considered this before.
Don't know if this is a factor or not, but it may drive me to move my antenna if I ever get serious about IFR flying.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 06-04-2014, 03:29 PM
Brent Colvin's Avatar
Brent Colvin Brent Colvin is offline
No problem with mine, yet.
Brent Colvin VAF#147
RV 7 0-360 CS Flying
Comm, Multi, Inst.
