  #21
Old 05-26-2014, 07:12 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by ColoRv View Post
Wraps are interesting, but what is the lifespan compared to paint and if the plane is bare aluminum under it, I fear corrosion. Aircraft Wraps quote was within 10% of my paint quote from GLO on the same scheme so without the same lifespan I couldn't go that route. Real interested to hear what the original poster paid his local installers. I would also like to hear what the vinyl weighs. We are always given percentages versus paint but that is highly questionable practice as it assumes what the paint weight is. What is the actual weight of the vinyl process installed?
I agree. What is the actual weight. Painting can be from below 15 lbs. to well over 30 lbs.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-26-2014, 07:39 AM
AircraftWraps's Avatar
AircraftWraps AircraftWraps is offline
I just responded in an email to this very question.
We complete an RV8 for Titan Aircraft Engines on Late Thursday. We used our new printed process instead of the “layering” on vinyl. Aircraftwraps is always searching for ways to further reduce weight. Layering brought our vinyl in at 1/2 the weight of an equivalent paint scheme. Printing promises to further slash that total. I’d rather “show” you the real number instead of simply stating it. We plan to reassemble the aircraft friday and reweigh for a final weight total. Hopefully, you’ll allow me to follow up friday-saturday with “real-world” numbers?
www.AircraftWraps.com
Have a paint price? Send it to me and see what we can do!
Please visit and Like us on Facebook.
https://www.facebook.com/AircraftWraps
Check our our Instagram photos - here
Please note, emails sent to hotmail are being delivered to Junk .
Old 05-26-2014, 12:14 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Half the weight of paint assuming what paint weight? What did the layering process weigh?
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 05-26-2014, 01:39 PM
Bevan Bevan is offline
Originally Posted by pmccoy View Post
The results look great. The cost was much less then paint, and the process was completed much faster.
Not to mention no harsh chemicals, solvents, spray equipment etc as with paint.
Was a little concerned seeing the propane flame used around the aircraft if there was any fuel or fumes in the tanks.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 05-26-2014, 02:03 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
That caught my attention as well! I would think a heat blower, commercial kinda like a hair dryer would be far safer.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 05-26-2014, 05:17 PM
Bevan
3M 1080 specifically states NOT TO USE FLAME/Torch and only heat guns in the Manufactures Technical Spec sheets.
Old 05-27-2014, 07:49 AM
Snowflake's Avatar
Is the flame/torch/heat gun intended to shrink that section of the vinyl, or to soften it so it can be stretched? It looks like it was only used near the canopy, where some compound curves were happening.
Given where it was being pointed, i'd be more worried about stress concentrations in the canopy bubble than fire considerations due to fuel... :/
Rob Prior
Old 05-27-2014, 08:11 AM
Sid Lambert Sid Lambert is offline
Guys that wrap in the field often use the propane torch because they lack power. Guys that own their shop will use a hair dryer or sometimes heat gun. A hair dryer is all that is needed and it doesn't burn you when you need to hold it. Some of the better guys can hold the dryer between their legs or arms and use both hands to apply.
This material will stretch easier and also release wrinkles when heated. You can literally ball it up then apply heat and it will look like it just came off the roll.
There are hundreds of wrap videos online you can see how this works. There is no magic to it. It is an art so I wouldn't advise attempting it on your own.
Edit: BTW, a propane flame will punch right through this material. Your canopy would not be damaged at that temp but of course could be if someone just held the flame in one spot.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 05-27-2014, 01:56 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Default Weight...
I just put one square foot of 3M 1080 bright blue on my store's gram scale. .5 ounce.
Please, someone reply what paint is per square or the total square feet on an RV-? (500 sq in a two seat would be my guess...puts vinyl at 16 pounds without primer or fillers). The low end of Mel's numbers.
Prep over fiberglass will be about the same or the weave shows. Pin holes do not show so much. IMHO. So add that to weight...
My -8 is half polished, went from 1018 to 1050 = 32 lbs but some other things were done that I did not record between weigh ins. My cowl and spinner are painted. Fly boys did the military markings and name on the nose. Local sign shop (that also do complete wraps) did the girl...
My wrap is a DIY, but so was the plane...LOL
Bruce, Katie, Hana and RV-8 HulaGirl
Old 05-27-2014, 02:37 PM
greghughespdx's Avatar
Your plane's a work of art. By the time I saw it at Nehalem Bay the other day and realized it was yours, you were gone headed into town. I'd be curious what the do-it-yourself process was like, and since I am considering a RV-8 build, I'd sure like to discuss in general. I'm over at Twin Oaks.
greg
