Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Engine Monitors
  #11
Old 05-23-2014, 06:10 AM
SR2500 SR2500 is offline
Default VM 1000 C Manual
I have one I can forward you. Please send me your email address off line. There were also a couple of models -- pre and post JPI. You can tell by the color of the back of the display, gold or silver. Mine is the pre-JPI model.
Best,
Jerry Folkerts
Old 05-23-2014, 08:39 PM
Glas467's Avatar
Glas467 Glas467 is offline
If you have the black box version, the manual is online at the JPI Tech website, do a Google search on VM1000C Manual and it will take you right to it.
Reggie
Old 01-11-2015, 03:38 PM
donswords donswords is offline
Default Fuel Calibration VM1000c
It's tricky to calibrate this unit for fuel quantity I've found. Still not successful. I want to calibrate it for both ground reading and flight reading. I have an RV-7. I've got the standard floats in the tanks. Does any one know or guess if I calibrate it with tail down only i would read more or less than is actually in the tanks during cruise? (Level flight) Thanks
