Old 05-23-2014, 08:43 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default electrical power consumption
I am curious, if somebody has measured electrical power consumption of his RV-12 (SLSA or EAB) to get an idea of how close the Rotax's internal generator gets to its limit of 20 amps during operation.
Is there some power reserve for more loads beside the standard avionics or is the generator already loaded as its max?
thank you very much for any numbes or experiences.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 05-23-2014, 11:09 AM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Chris, technically a ASTM compliant install is only allowed to use 85% of the rated power of an alternator or generator. With the 912 alternator, this means only 16.4A is usable.
From the data we have, and RV-12 with a Dynon SkyView system in it draws about 13.2A when all the lights are on and the autopilot is engaged.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 05-23-2014, 11:53 AM
kevinl4000's Avatar
kevinl4000 kevinl4000 is offline
How many amps for a second Skyview screen?
Kit #120-666 "The number of the beast"
http://kevinsrv12build.blogspot.com
Old 05-23-2014, 03:19 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Dynon site lists 3.5 amps @12 v.........
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 05-23-2014, 05:18 PM
kevinl4000's Avatar
Thanks. Might be doable as long as you don't have the lights and second screen on at the same time.
Old 05-23-2014, 07:16 PM
Phantom30's Avatar
The Dynon Skyview supports "Vertical Power" monitoring (software upgrade) for $275. This would give you an alarmable(sp) total electrics monitoring system. Will be in my bird!!
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 05-24-2014, 12:10 AM
Thumbs up
Thanks for your postings. I favor to go with 2x 7" Dynon screens
Old 05-24-2014, 01:09 AM
Hotscam Hotscam is offline
I am flying with two SV1000's apilot, ligthing and Adsb for two years now.
I have a switched fuel puump. The second sv has no backup battery
All consumers on except the pump the load is below 85% measured.
With the pump it is 95%.
I switch the pump on in take off and landing.
No problems at all
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
