05-05-2014, 09:43 AM
recommend in the future you overfly the center of the ATL bravo space, you'll have better results than cutting the arrivals corridor
05-05-2014, 05:25 PM
Great post!
That there is some "Git Up And Go!"
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
05-19-2014, 01:09 PM
To Bill and MarkW,
What is the highest TAS you can achieve at 12,000+ DA? Highest RPM achievable? I'm curious to know what the IO-320 vs 0-360 with FP props can do at altitude. Any other RV-9s with such >12,000 data points?
Thanks, Tyson
05-19-2014, 02:46 PM
RV9 wing vs RV7/8 wing
I know that the RV9 wing has a different airfoil section with better low speed performance then the RV7/8 wing, but what would explain the better high altitude performance?
05-19-2014, 02:51 PM
VAF Moderator / Line Boy
Higher aspect ratio.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-19-2014, 02:56 PM
Right!
Higher aspect ratio: I should have known that from all those aerodynamics classes I took in school...
05-19-2014, 03:36 PM
I don't seem to get any better speed because of the lost manifold pressure.
I loose IAS but True says about the same.
I can fly WOT, lop and it is 155 kts about 2500 rpm.
Interesting is wind direction though. I flew from Orlando to Charleston Friday and had a tail wind coming and going just because I was able to pick my altitude.
Going North in the morning wind was 310 down low but as you climb wind moved to about 240. This gave me a 20 knot tailwind most of the trip @ 11k. On the trip home that evening/night is was about the same so I flew lower @ 8k. Tailwind during part of the trip. Even @ 8k we used O2 because we had it and it was dark thirty by the time we landed.
Higher without the advantage of wind doesn't make me faster but it reduces fuel consumption. If I remember @ 11k I was WOT and 63% power. Running about 6.5 gph. Lower and same speed @ 80% power and I would burn 8 gph.
05-19-2014, 04:20 PM
The difference between Mark's IO-320 and my O-360 is that I typically run mine at 50% power LOP (Love my P-mags!), burning 6.1 GPH, and truing at155 Kts at 8500'. (My pictures indicate 20.8" MAP & 2500 RPM at 10,430 DA.)
The O-360 will drink more fuel but then I can also go faster. I just returned to Houston yesterday and was trueing out at 165 kts while burning around 8 to 9 GPH. (I didn’t take pictures but did use the SkyView to do some screen grabs and those pictures on the flash drive, which is sitting in the plane.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
05-19-2014, 04:31 PM
My goodness Bill, you're just now getting around to exploring the -9's lovin' for way up top? Come on in, the water is fine...
Vlad, your map is turned the wrong way! Don't you know North is always Up.
Scott Card
CMW E-Lift
05-19-2014, 04:55 PM
Scott, you are going to hate that -8 because it just doesn't do that well up high. I suggest you let me come take it off your hands. How does 20 bucks sound?
Bill R.
SC86 - Easley, SC
