Old 05-15-2014, 09:16 PM
jester jester is offline
Default AOA or stall horn question.
I have purchased an rv6a and would like to install an aoa or stall warning device. What is the simplest way to do it .What product to use . My first post so I hope I am in the right place.Thanks for any help.
Old 05-15-2014, 09:36 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Talking Welcome
....Welcome to the V.A.F. Nicky, good to have you!
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 05-15-2014, 10:22 PM
Master Designs's Avatar
Master Designs Master Designs is offline
The Bendix King KLR-10 was just released. Super cool, but $1,500.
https://www.youtube.com/watch?v=maEmTsWOSvc
Robert Kramar
Gilbert, Arizona
  • Vans RV-6A
  • Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
  • Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
Old 05-16-2014, 02:47 AM
mike newall's Avatar
mike newall mike newall is offline
An AOA properly calibrated will give you a much better safety margin as you will be able to see the AOA increasing whereas a stall warner gives you less information.
Yes, an AOA is going to be a little more expensive, but when you operate into a short strip using AOA, your confidence will be a lot higher.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 05-16-2014, 05:07 AM
Walt's Avatar
Walt Walt is offline
I think AOA should be required equipment!
This is one of the best stand alone units IMO:
http://www.advanced-flight-systems.c...s/AOA/aoa.html
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-16-2014, 05:38 AM
60av8tor 60av8tor is offline
This hits the nail on the head. Regardless of difficulty, you owe it to yourself to have AOA installed. I believe once one has it, one would not want to be without. The feedback you get (well before critical angle) is invaluable. It's great to see just what the AOA situation looks like on the classic base to final turns. Maneuvers that you once thought were well within the "neutral" zone may surprise you. If anything it makes you more cognizant of being low and slow.
Jon
Old 05-16-2014, 08:05 AM
johngoodman's Avatar
johngoodman johngoodman is offline
Being a former Naval Aviator, I'm a big believer in AoA. In fact, I have three different systems in my RV-10. The one I like the best - and the cheapest - is the Lift Reserve Indicator. It is purely analog, except for the light inside the mechanical gauge, for (ugh!) night flying.
I mounted mine where it should be - on top of the glare shield.
There are lots of brands of LRIs out there, and they are pretty much the same. I'd look for the cheapest one....
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 05-16-2014, 08:25 AM
Sam Buchanan's Avatar
been here awhile
John
I concur. I've been flying an LRI in the RV-6 for a long time and it is simple, inexpensive, reliable, and my primary instrument for managing the pattern and landings.
http://thervjournal.com/liftreserve.htm
As a bonus the LRI probe can also drive the AOA indicator in the Dynon to provide an audible alarm.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 05-16-2014, 10:02 AM
N941WR's Avatar
N941WR N941WR is offline
Welcome!
Does your new plane have a Dynon EFIS installed, by chance? Do you want one?
Dynon makes a very good AoA but you have to have one of their EFIS's and Pitot tubes.
Installing their pitot and the AoA line isn't that difficult.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-16-2014, 10:11 AM
Sig600 Sig600 is offline
Originally Posted by N941WR View Post
Welcome!
This is what I was going to post.
Dynon pitot/AOA combo and a D10 will give you what you're looking for plus a battery backed up EFIS.
If you want to drop a little more coin, I have a 10" skyview with the same pitot/AOA. Works great, plus all the features of the SV system.
Garmin has jumped into the water with a pitot/AOA system on G3X too.
Others have mentioned the AFS, LRI and Bendix systems. Lots of choices out there.
Beware, so many cool toys out there your wallet will get really light really fast!!!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
