Old 05-14-2014, 06:45 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
I believe checker board rudders add an extra 5 knots to your cruise performance (Maybe the more blocks the faster )
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 05-14-2014, 12:40 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Checkerboard rudders help, but lots of red in the paint scheme helps to go even faster.
3" squares on mine.
Originally Posted by brooksrv6 View Post
I did mine in 3". Went to a local sign shop that cuts vinyl and had them cut me 2 "spray mask" of 3" squares. Painted rudder white, applied mask and shot black, removed mask and cleared.
The builder of my RV-6 did exactly the same thing... got a spray mask made from vinyl at a local sign shop.
Neal Howard
Airplaneless once again...
Old 05-14-2014, 03:25 PM
Capflyer's Avatar
Capflyer Capflyer is offline
And if they are put on as diamonds you get an extra kt up to 6kts. Do the whole VS & rudder and it's up to 7kts!
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 05-14-2014, 03:39 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Thumbs up
3" squares on mine.
That's a beautiful paint job. Might even pass for Aggie maroon!!
Old 05-14-2014, 04:11 PM
Neal@F14's Avatar
Thanks!
The builder said it is Acry Glo solid Cabernet Red, a color that's supposedly been discontinued but can still be special-ordered from S/W for extra $$$ . In subdued lighting conditions it does look maroon, but in bright direct sunlight it definitely looks more red than maroon.
Neal Howard
Old 05-14-2014, 11:52 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Originally Posted by Kyle Boatright View Post
On my RV-6, I made the checkerboard 3 columns wide, with the blocks getting wider from the top of the rudder to the bottom.
Here's a pic:
http://www.airport-data.com/aircraft...000906214.html
I shamelessly (with permission) stole Kyle's rudder paint ideas... Hand masked the hard way. Don't forget to put some on the flaps too...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 05-15-2014, 04:48 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default On my RV-4...
I used vinyl squares, about 3" IIRC:
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-15-2014, 06:04 AM
Tom Martin Tom Martin is offline
This was done with a decal
[IMG][/IMG]
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 05-15-2014, 06:06 AM
machineman machineman is offline
https://picasaweb.google.com/lh/phot...eat=directlink
Talk to Eddie...
http://edsaircraftrefinishing.com/?attachment_id=132
More Pics
https://picasaweb.google.com/1106267...eat=directlink
N485AM RV-7 950 hrs
CFI
TMX IO360
Garmin G3x
KTAN Massachusetts
https://picasaweb.google.com/1106267...85AMMILEIKARV7
Old 05-15-2014, 06:22 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
I put 'em on all three of my rudders; improves roll rate and crosswind handling characteristics.
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
