Go Back   VAF Forums > Model Specific > RV-9/9A
Old 05-07-2014, 10:16 AM
Default Forward spar on vertical stab
Hi guys,
Did you use dimple dies or machine countersinking on the VS forward spar? The gauge of aluminum is kind of an in-between thickness, and I'm not sure how to proceed. Thanks!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 05-10-2014, 01:50 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Dimpled
I had a pneumatic squeezer and dimpled. Just one case
Good Luck!
Alan
RV-9A N984AW
Old 05-10-2014, 02:45 PM
davidwv davidwv is offline
I dimpled also.
David
Martinsburg, WV
RV-7 Flying
RV-4 Under Construction
Old 05-10-2014, 04:48 PM
mikehoover's Avatar
mikehoover mikehoover is offline
The parts list I have indicates that the Vertical Stabilizer Front Spar VS-702 is .032. I dimpled mine.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 05-10-2014, 06:26 PM
RVdreamin RVdreamin is offline
Pneumatic squeezer and dimpled mine as well.
Jimmy Black
RV-9A
Started Finished 10/16/14
Wings Finished 4/9/16
Fuselage working electrical
Finishing Kit received 9/11/19
HWY
VAF paid 2019
Old 05-11-2014, 04:28 PM
longranger's Avatar
I don't know about the -9, but in the manual for the 7, Chapter 5 on construction processes says the thinnest material than can be machine countersunk is 0.032, but recommends dimpling 0.040 and thinner. The only exception I've run across so far is on the aft row of rivets attaching the fuel tank skin to the rear baffle, where they have you countersink the skin to make the insertion of the baffle easier. I have read where some builders even dimple these holes without issue.
RV-7 TU 904KM (reserved)
Construction Log
Old 05-12-2014, 03:49 PM
Thanks for all the replies, guys. I ended up dimpling with a pneumatic squeezer, and the dimples formed nicely. I guess with that thickness you could go either way, but I'm glad I dimpled.
It gave me a chance to pull out the micrometer and reacquaint myself with reading it.
Doug
RV-9A "slider"
Tail number N427DK
