Old 04-20-2014, 07:50 AM
Stockmanreef Stockmanreef is offline
Default Fuel Vent line question
A couple questions:
1. Does the fuel line flare fitting get any tank sealant? The reason that I ask the question is that at the bottom of the page in bold it says "Double check that the vent line is clear and has not become clogged with sealant." How would sealant get into the line if it was not put on the connection between the aluminum tube flare and the fitting.
2. How does one torque down the fitting with a torque wrench? The only way I can figure it out is to go to HD and buy the correct size open ended wrench to fit on the torque wrench, since a socket won't work.
3. Should I cover the vent line bulkhead union fitting, nut, and tubing with sealant to ensure that not leaks will occur?
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 04-20-2014, 09:01 AM
rapid_ascent rapid_ascent is offline
What you need is what is called a flare nut socket or sometimes a crowsfoot. I bought a set of craftsman sockets on ebay. They have an opening that allows you to slide it on over the line. Here is a link at Sears.
http://www.craftsman.com/craftsman-1...p-00942049000P
You can find these as sets of different sizes or as singles.
Once you get these you can use your torque wrench. Be aware that you need to make an adjustment for the torque that is read off of the wrench since you have adjusted the lever arm of the wrench. That calculation is available in the Aircraft Mechanics Handbook.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-20-2014, 09:17 AM
Ron B. Ron B. is offline
The sealant Van's is probably referring to would be uncured sealant used in the construction of the tanks. They are saying to make sure you don't put the end of the tubing into it and create a blockage.
You may want to apply sealant to the outside of the nut on the vent line to make sure it will not back off as it is just about impossible to reach after the tank is closed. So #3 would be a yes for me.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 04-20-2014, 09:22 AM
JoeLofton JoeLofton is offline
Alternative methods of torqueing aluminum fittings are given here:
http://www.vansaircraft.com/pdf/Torq...m_Fittings.pdf
Old 04-20-2014, 07:06 PM
KCBerner's Avatar
KCBerner KCBerner is offline
If possible, you can also just attach the crow's foot at a 90 degree angle to the torque wrench and no change or calculation is required.
K.C.
RV-14A #140026
Wings 70%. Emp 70%
Happy to be a 2020 =VAF= contributor
Old 04-20-2014, 07:51 PM
KC-
I bought a crows foot today. So even thought you extend the arm on the torque wrench, you don't need to recalculate?
I did the calculation and it does not change much with the crows foot on it any way. 40-65 in-lbs changed to 37-62 in-lbs.
Thanks for the replies.
ken
Ken Stockman
Midland, MI
N73XP
Old 04-20-2014, 08:18 PM
rzbill's Avatar
rzbill rzbill is offline
Correct. It has been reported here that some military guidelines ignore small changes in arm length. Personally, I think that it is kinda' slack. I'd rather do the calculation as you have, and then choose a value that cannot be wrong (like 55 for instance), or use the 90 degree trick.
If you assemble the crows foot at 90 degrees to the handle of the torque wrench, you are NOT extending the arm. This geometry trick allows one to use the unmodified torque values.
Bill Pendergrass
ME/AE '82
Old 04-21-2014, 07:27 PM
KCBerner's Avatar
First of all, I apologize for the bad drawing. I don't have much to work with on my home computer.
In the picture below, the torque wrench (purple line) and the crows foot (red line) are at a 90 degree angle to each other. The important thing for torque is the "cross product" between the vector and the force applied... ie the moment arm. That's shown in the drawing here and is the same length as the original torque wrench...no corrections necessary. Bottom line is that the only important thing is the distance at a right angle to the force vector from the force vector to the fastener...times the amount of force applied. Torque = r "cross" F
In this drawing, the torque wrench and crows foot are in line. You can see how the moment arm between application of force and the fastener is longer for this case. In technical terms, the length of the crows foot itself is included in the cross product. So in this case you would have to compensate for the additional moment arm using the calculations given earlier.
Sorry if I've bored most and confused the rest....
K.C.
RV-14A #140026
Wings 70%. Emp 70%
Old 04-21-2014, 07:45 PM
Ah?.. I see. I just assume that I would put on the crows foot as per picture 2 (lower picture).
Thanks again.
Ken
Ken Stockman
Midland, MI
N73XP
Old 04-27-2014, 08:22 AM
How many people use these fittings between the aluminum tubing and the fittings?
http://www.aircraftspruce.com/search...DEL%20FITTINGS
Ken
Ken Stockman
Midland, MI
N73XP
