Do RV-12 Cowling after Engine and Spinner
The RV-12 cowling is a tight fit and will need to be put on and taken off many times before it is finished. I just completed mine and am so glad I installed the engine, muffler, and spinner first. The cowling is a lot of work, and I definitely would not recommend installing it first.
If I were doing my cowling again I would trim the pieces, sand the top and bottom insides, give the insides a coat of West 105 epoxy resin, install the piano hinges, then install the cooling duct. I had to modify my cooling duct to have adequate clearance around the cylinder 2 exhaust pipe spring.
Moving the oil cooler forward one inch takes some doing but is an elegant solution to the high oil temperature problem when flying in hot summer temperatures. Best to do this mod while installing the cooling duct so the oil cooler mount part can be cut out and moved forward before it is epoxied in place.
