Old 04-20-2014, 11:18 AM
jimfaber jimfaber is offline
Default Nose Wheel Maintenance
Hi Guys,
I am in the middle of my annual and I am wondering what is required on the nose wheel. I have checked the breakout force and added grease to the zirc. The wheel bearings look like a sealed unit. Does it need any maintenance?
I also lifted up on the strut with the nose wheel off the ground and it seems firm except for a small amount of play in the linkage.
Any suggestions?
Jim Faber
Old 04-21-2014, 07:34 AM
After doing some more research, I found out I have the Matco front axle system. The specific question is "does the wheel bearing need to be cleaned and repacked during the annual inspection?"
Old 04-21-2014, 08:25 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Aside from inspection and cleaning, I just grease the zerk fitting, check the breakout force (I err on the side of higher force), and re-pack the bearings. For me, the nosewheel bearing grease is always more dirty than the main wheels. I figure it probably doesn't seal as well.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
