Old 04-13-2014, 01:05 AM
ao.frog ao.frog is offline
Default Upgrading from Vans std tailwheel to a lightweight TW: here's the numbers I found:
Hi all.
I've just replaced Vans std TW with a lightweight version bought from Vince and Blake at Flyboy Accessories, and here's the numbers and experiences so far.
The TW looked like a piece of art when I took it out of the box:
I also bought some spareparts because those springs and little things have a nasty habbit of getting lost.
First I compared their diameter:
Vans TW is 15 cm diameter.
FlyBoys is 14 cm.
Then I compared the width:
Vans is 5,5 cm.
FlyBoy is 3,5 cm rubber and 5,5 including the bearing.
Finally the weight: Vans is 1100 grams
FlyBoy is 740 grams:
Mounted on the fork, Vans TW distance from the floor to the center was 68 mm:
Flyboy was 65 mm above the floor:
Finally I measured the angle of the fuse:
Both wheels indicated an angle of 10,9* and that makes sense since the height above the floor was almost the same.
I haven't flown with the new TW yet because bad weather, but next week it's forecasted to clear up. Then it'll be time for flying and I'll post my experiences afterwards.
In a month or so, I'll get hold of some calibrated weights and weigh in the plane with both the old and the new TW.
It'll be interesting to see how much (if any?) the CG has moved fwd.
Maybe someone else has done this already?
Stand by for updates.
Lastly: Blake and Vince is very nice to do business with and they provide very nice customer care!
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 04-13-2014, 05:31 AM
Ken Martin Ken Martin is offline
Thanks for posting the comparison. I look forward to reading your flight review. I'm considering the same upgrade on my -7 build.
Ken
?Aviation is not so much a profession as it is a disease.? Anonymous
Building an RV-7
Empennage complete, fuselage 75%, wings 75%.
Old 04-13-2014, 05:41 AM
PaulRV6 PaulRV6 is offline
I am also considering the same upgrade. Will be waiting for your update to see if the CG changed.
Old 04-13-2014, 05:54 AM
Brantel's Avatar
Brantel Brantel is offline
I just did this upgrade a few weeks ago.
One of the unexpected benefits was that the LW wheel is of a much harder durometer of rubber and it does not bounce as much!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-13-2014, 08:25 AM
AX-O's Avatar
AX-O AX-O is offline
That is Dayton's tail wheel. Same guy that makes Vans throttle quadrants. I noticed a big difference during taxi ops. Hope you like it. I love mine.
Btw, on my 4 the tailwheel spins slowly in flight.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-13-2014, 10:42 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Dayton's TW
I received one of Dayton's first production tail wheels.
My post is long gone, but it said it made me younger, lighter, better looking, faster, more responsive, and in general a better pilot.
Good job Dayton!!!
Every RV flyer need to get on of these tail wheels.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 04-13-2014, 08:38 PM
rvmills's Avatar
rvmills rvmills is offline
Good job Dayton!!!
Concur..Dayton's TW is a nice piece of gear, and Vince and Blake are great to work with!
Mine has worn very well, even in the crucible of Reno-Stead home field ramp ops?I have a heavier-than average tail weight, and we have the most cavernous expansion joints of any ramp I've seen (and there is a tar flow off the coast of Madagascar, where all the annual refill goop must be going). The DM/FB lightweight tailwheel has earned its stripes there!
Mine spins in flight too?and when Axel and I fly formation, they spin in sync!
Jay's right on all counts?except for the faster part?but Dayton, Vince and I have something up our sleeves. Tell ya all about it?in mid-September!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 04-14-2014, 11:09 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
I built my 8 and did the first flight on august, 2010
On november 2011 I upgraded the tailwheel with the FlyBoy fork and lightweight wheel, I had an incredible improvement in ground control of the aircraft during taxi, takeoff and landing roll.
It's a great products, easy to promote
ps: shadows are strange in this photo but the tail fork is perfect
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 04-14-2014, 12:08 PM
don.olandese don.olandese is offline
Default used one originally but it's on the shelf now...
am using the Van's now. the improved product is way smoother and higher quality in general; I used and loved it for about 200 hours, but then the rubber separated from the metal hub. that made for really crappy taxiing and I replaced it "temporarily" with the van's model and shoo-gooed it. will put it back on the airplane at the next CI, most likely, and the Van's will become the Shelf Stock. BTW, Shoo Goo is great stuff too.
Old 04-14-2014, 11:40 PM
Default Flight report
Yesterday, I did the first flight with the new TW.
It was only one flight with one takeoff and one landing, (no T/G's since I'm in the break-in phase) so my experience with this TW is limited to say the least.
BTW: I have Vans TW chains with the std slack shown on the drawing.
I found that the steering during taxi was slightly more "stable". (the plane didn't need quite som much steering with the rudder-pedals to stay on course)
During takeoff, I didn't notice any difference.
During landing rollout, the steering felt slightly more stable. (10-15 kts X-wind)
The TW-noise heard inside the plane during all phases where alittle different, (slightly different rumble) but the noise-level was the same as Vans TW.
All-in-all: not any big differences, but at least it's some approvement.
Hopefully I'll find that the CG has moved alittle fwd when I'll weight the plane in a month or so.
Also: during postflight, there was NO GREASE slung around on the TW fork or the rudderbottom! BIG improvement!
It's good to know that the bearings are sealed so no dirt or dust can enter the bearing. That's a BIG advantage in my book.
PS: I'll have a friend join on me soon to see if the TW spins in flight. Funny thing....
