Go Back   VAF Forums > Model Specific > RV-6/6A
  #21
Old 03-16-2014, 12:51 PM
kjlpdx kjlpdx is offline
I have my strobe power unit mounted on the floor behind the battery. it is covered with a screwed down lid. above that is a box for WAC chart book, snacks, water, camera, x/c stuff, all of which can easily be reached by pilot and passenger. another mod was to hinge the front corner of the battery box for quick access for charging without having to remove the entire cover. [which will happen at strange airport in the morning when you discover you left the main on all night and you need to get going because weather is moving in, of course]
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
Old 04-09-2014, 09:33 PM
dwschaefer's Avatar
dwschaefer dwschaefer is offline
Default RV-6 Tunnel
Sorry for the late reply ... yes .. I put in a tunnel .. it carries a gaggle of wires, the fuel lines, fuel pump etc. I'll dig up the pictures and shoot them to you.
Regards,
David W. Schaefer
N142DS RV-6A "Nerdgasm"
www.n142ds.com
Old 04-10-2014, 09:46 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Rob,
Thanks for the tip on the Bison Bag. I got one for my birthday and it is totally cool. Love it.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 04-11-2014, 09:24 AM
gyoung's Avatar
gyoung gyoung is offline
I made covers for my AFP fuel pump and the heater diffuser. I tried to use the RV-7 pump mount but the spacing between the angles was off just enough to not let it work without a lot of mods.
Greg
1950 Navion - flying
RV-6 - 18 yrs and 99.5% done
1940 Rearwin Cloudster project next
4 L-2 projects on deck
Old 04-12-2014, 06:24 AM
GLPalinkas's Avatar
Vince, I love the way you secured the top of the tunnel with hinge material for a quick release way to inspect. Great idea. I have been looking for some way of hiding my wiring (I also have my red cube in that area near the firewall).
I especially like the curve to the side walls of the tunnel. Did you have to roll it a little like the forward sections of the rudder and elevators or is there enough flex that it eventually curves on its own? It's looks great and eliminates the "boxy" form factor.
Venice, Fl
Old 04-15-2014, 08:42 AM
vfrazier's Avatar
Gary,
Van's makes (or used to make) a piece of rolled aluminum for use as wing root fairings. I think I had those pieces in my junk box for 20 years until hitting on the idea of using them for the tunnel sides. They are quite solid and definitely won't roll on their own.
The hinges are a bit of a pain to install, but I couldn't think an any alternatives that gave enough flexibility to get that stuff installed in a rather cramped area. Perhaps a velcro hinge would be just as good? Hmmm, too bad I didn't think of that until just now.
Vince Frazier
www.f1aircraft.com
