04-07-2014, 05:29 PM
oil cooler spacer
Does anyone know if there is an offset/curved/canted spacer to go between the oil cooler and the opening on the number 4 baffle on an IO360 parallel valve RV8. I have the large oil cooler and have also done all of the checks (oil flow, crimped oil line, vernatherm,etc) to make sure that my problem is not airflow. I have flown the airplane for 369 hours and I constantly struggle with marginally high oil temperatures. I'd like to get this problem squared away before the summer flying season gets started. Can anybody provide a drawing or better yet tell me where I can find one already built?
04-07-2014, 07:26 PM
I would also be interested in this but for an rv9 o320.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
04-08-2014, 06:09 AM
spacer
It seems that I've seen one here some time ago. It was built on a cant to keep the oil cooler from touching the engine mount. Does anybody remember the post?
04-08-2014, 07:50 AM
Robbie Attaway
The stand off referred to was manufactured by Robbie Attaway. I purchased one from him about two years ago but was unable to use on my RV9. I'd be delighted to sell this for $50.00 plus ship. I paid around $100.
Paul
04-08-2014, 11:02 AM
Out of curiousity, Paul, why were you unable to use it? Did it just not fit the geometry of the RV-9 mount?
The reason I'm interested in this is that my hot summer temps can get up slightly over 220 (and more if I let it) and others have recommended either (a) a larger oil cooler or (b) one spaced just a bit further from the hot cylinder. Both options, however, would require an angled spacer of some sort that would be a bit tricky to make myself.
Steve M.
Ellensburg WA
04-08-2014, 12:50 PM
Steve, it would be interesting to compare our installations. I don't have a problem in summer months, but have a hard time getting oil temps up to normal in winter months. I have my cooler blocked almost completely off in the winter, and about 60% in the spring.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
04-08-2014, 01:01 PM
I still have to block it at certain times of the year in order to get my OT up to 180. Almost all the way blocked off from December-February, then I have a smaller cover plate to use Oct-Nov and Mar-Apr. Yours is firewall mounted isn't it? Mine's on the back baffle.
Steve M.
Ellensburg WA
04-08-2014, 01:14 PM
Mine is mounted on the baffle. I mounted it as high as I could get it.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
04-08-2014, 05:00 PM
spacer
Paul,
I will take the spacer. I sent you an email. My email is Watson.david@ccbg.com.
David Watson
850-508-3067
