Old 03-27-2014, 10:10 AM
bret's Avatar
bret bret is offline
Default Do you have a girdle?
Check out sky dynamics new cylinder girdle. http://www.skydynamics.com/frame.htm They claim to have fixed the cracked baffle problem, and engine flexing by tying the cylinders together. interesting product!
Old 03-27-2014, 02:16 PM
airguy's Avatar
airguy airguy is offline
They also claim increased horsepower, which causes my BS meter to twitch more than just a little bit. It's gonna take a lot of engineering drawings and equations to convince me you are going to get any more power out of that arrangement.
"These girdles substantially limit the cylinder's natural X-Y movement to increase durability and horsepower in high power applications
Old 03-27-2014, 04:10 PM
EFG EFG is offline
Default Goin' Girdle
I think their argument is like stud girdles on high HP automotive applications, the girdle doesn't MAKE horsepower, it ALLOWS more horsepower to be made without shortening the life of the engine.
They might want to work on their wording there.
Valvetrain stud girdles are well proven in V-8s, not so sure that directly applies to "cylinder" girdles on a Lycosaurus however. But, ever forward with innovation.
Here are the ones I run on my small block TPI chevy 383, 10.5 to 1 compression.
http://www.jegs.com/p/AFR-Airflow-Re...20890/10002/-1
Old 03-27-2014, 07:01 PM
ColoRv's Avatar
ColoRv ColoRv is offline
I tried pretty hard to buy one of their maxi sumps at one point. Never had any luck and when I spoke to the owner his answer for when they would be available was something like 'when we find a foundry that will make them for us'. A couple months later, still no joy so I went with Superior for far less money. I can find a foundry to make me a lifelike rendition of a pile of dog poo made in magnesium in about a week. Something is off when a client is standing with a fist full of money and you cant sell them your flagship product in two months. I hope they got it together, but in short...if its not in stock..don't hold your breath.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 03-28-2014, 09:02 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
My BS meter just went up in smoke after I read that...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-28-2014, 09:13 AM
aerhed aerhed is offline
For some reason I'm picturing case cracks all over the place.
Actual repeat offender.
Old 03-28-2014, 10:13 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Just what I was thinking. Anytime you constrain motion that has worked for a couple of million hours, you are going to transfer that stress somewhere....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-28-2014, 10:53 AM
RVDan RVDan is online now
I am also nnot a fan of Magensium in what might be high stress vibratory loads. It loves to work harden and crack.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 03-28-2014, 10:58 AM
BillL BillL is offline
Absolutely, all the above. Linear motion on one head results in torsion on the adjoining barrel assembly? Hmmm . . . . Cool idea, but, I will pass.
Bill
RV-7
Lord Kelvin:
Old 03-28-2014, 11:54 AM
DanH's Avatar
DanH DanH is offline
I'm just spitballin', but try this theory.
The port cylinders bend a wee bit downward and the starboard cylinders bend upward, both in reaction to piston side load during the optimum crank angle portion of the power stroke . Side loading gets worse as combustion gas pressure is increased, or (generally) as stroke is increased. The bending cylinder can be modeled as a spring. Most of the available energy goes into pushing the connecting rod and some goes into compressing the spring. Of course the spring stores the energy and returns nearly all of it when the opposing pressure is released, but by then it's too late to result in crankshaft torque.
And yet, a large diameter cylinder would be quite stiff in torsion, and if the cylinder were monolithic, rather than a two-piece screwed head and barrel assembly, it might withstand the forces pretty well.
You know, cylinders like the ACE AX50 cylinders on Kevin's test mule:
On the other hand, if one borrowed the idea without considering the screw joint, life may be compromised. Unacceptable to most, but if your customers are performance types who clearly don't mind some loss of engine life in return for HP....
Dan Horton
RV-8 SS
Barrett IO-390
