Originally Posted by jrs14855
ECI fuel injection system is essentially a Contintental style system adapted for use on a Lycoming.
Yep, originally it was known as the Airmotive Engineering fuel injection system.
It is so similar to the Continental system that the same set of gauges/fittings/valves/hoses that you use to calibrate the fuel injection system on an old Beech Debonair's IO-470 works perfect for calibrating the ECI system on an IO-360 in an RV
