Go Back   VAF Forums > Model Specific > RV-9/9A
  #791
Old 02-24-2014, 12:21 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Manny, he is setting the wing sweep alignment. Done prior to drilling the hole for the rear spar attachment.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-24-2014, 12:46 PM
MarkW's Avatar
MarkW MarkW is offline
If you drop one from the inboard and outboard of each wing you will have four that should line up. Nothing to reference on the fuse.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 02-24-2014, 01:35 PM
KRviator's Avatar
KRviator KRviator is offline
The idea is to have the 4 plumb bobs in line, one at each tip and each root, and also to measure from a rivet of your choice on the wingtip to a reference point of your choice on the tail.
When the measurements are the same, left and right, and the 4 plumb bobs are in line, your leading edge is as square to th fuselage as its going to get.
If you do not measure the distance from the tail, you may have a perfectly inline leading edge that is not square to the fuselage. In my case, I used a wingtip rivet, and the join line for the HS, that gave a measurement of around 5,115 mm. So, if I had one side that was 5110 and the other 5120, add them up and divide by two to find the "ideal" measurement and adjust the sweep to get it.
There is no hard and fast rule as to what your reference points must be, just make sure you use the same point on each wingtip.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 03-24-2014, 09:23 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default 2 years Down!
After this windscreen fairing i'm about out of things to do in the garage. Substantial completions in the last year include: Slider Canopy, Cowling, Avionics, Engine and Firewall Forward. The only thing i'd hate to over again was the cowling and FAB .... hundreds of iteration of on-again-off-again. The most rewarding and was the avionics wiring (big help from Jenny at Stein) but this was the most fulfilling work for me. We've had two awesome kids in the process and the wife still has her parking spot
Nomex suits and their ready
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 03-24-2014, 09:34 PM
propsync's Avatar
propsync propsync is offline
Lookin' good.
Tom B
Tampa, FL
EAA - Tampa Exec Airport
Old 03-25-2014, 12:12 PM
DeltaFox DeltaFox is offline
Default re:2 years Down!
Looking great Derek! Very nice work.
Dale
RV-9A Airworthiness certificate Oct 2017,
first flight 11/18/17, testing completed Mar 2018.
Now free to move about the country.
http://dalesrv.blogspot.com
2020 Dues Paid
Old 04-07-2014, 09:35 PM
bruceh's Avatar
bruceh bruceh is offline
Default Status is Done. Ready to fly!
Obligatory photo of the finished RV-9A.
Airworthiness inspection completed 4/6/14.
First flight to come soon...
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 04-07-2014, 10:07 PM
propsync's Avatar
Don't get any bugs on it.
Tom B
Tampa, FL
Old 04-08-2014, 05:43 PM
flightlogic's Avatar
Epsound:just a thought. Look at GRT mini efis as a budget primary.
Designed for backup, but might work for you.
I have one on order to go left center in my 9. Synthetic vision is too cluttered.
Look out the window!
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 07-26-2014, 01:21 PM
whd721 whd721 is offline
Default Final assembly
[IMG][/IMG]
Starting Final assembly (I Hope).
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, ?Simplicate and add Lightness?
