03-23-2014, 11:49 PM
Oops Pop Rivet?
The previous builder didn't drive the rivets on a wing skin properly. Most of the rivets I was able to reach with a bucking bar and drive properly. However, there are two rows that I cannot reach and am replacing the under-driven rivets with MK-319BS rivets. I have found a few holes that he over-drilled to 1/8". I think he used the Oops rivets here (4 shank with 3 head).
Do they make such an animal in pull rivets? I took a stainless rivet on the drill press and sanded it down to work, but it was a chore.
Thanks for your help with this.
Larry
03-24-2014, 01:01 AM
Oops Rivets
Hi Larry,
I believe a Cherrymax CR3214-4-xx is equivelent to the 1/8th NAS1097 (oops rivet). They are available in several grip lengths. The "xx" represents the grip length and is determined by reference to Cherrymax catalogue .
Michael Brooks
RV 9A QB
Flying
03-24-2014, 08:04 AM
I use the MK-319BS rivets frequently, but I'd really pause for thought before I'd use them for two entire rows on a wing skin. Even if they were strong enough, the potential for galvanic corrosion along the joint would give me the willies.
Perhaps someone with a better memory can show you the Alcoa reference that talks about how even poorly set rivets that look like heck still develop something like 90% of their intended strength.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
03-24-2014, 08:32 AM
Originally Posted by bugsy63
Hi Larry,
I can confirm the existence of this size rivet. It has a head of the -3 but shank of -4 (1/8") They lay flat nicely. Not cheap but a good solution option.
+1 = look in the Cherrymax catalogue for the correct part number.
Bill
RV-7
Lord Kelvin:
03-24-2014, 08:43 AM
This link might help:
http://www.vansairforce.com/communit...hp?t-6903.html
Chris
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
03-24-2014, 09:02 AM
Vans early RV-6 instructions allow an entire wing surface to be riveted with MK-319BS rivets as an option.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-24-2014, 11:20 AM
Thanks for all the help and guidance here. I have found articles by Van, indicating that the MK-319 could be substituted and have equal strength or at least strength up to the job on the wing skin.
My issue here is not poor looking rivet sets. I would accept them on the center wing skin rivets. Many of the rivets on one wing were barely hit. The shop head was very long and very thin and in many cases could see the exposed edge of the hole. A few were even loose and in some spots the skin wasn't tight to the rib. These HAD to go and I really didn't want to pull the whole skin again (P/B did it once, hence all the problems). I would accept an ugly rivet if sound.
Even if they corrode over time, I still think that I am better off than what I had. I believe that these two rows in the center of the skin are not highly structural. I believe that the rivets on the four edges of the skin really hold the shape (attached to stronger elements) and the center ribs really hold the skin flat to allowing the skin to hold the structural shape.
After more investigation, I found that most of the 1/8" holes had been dimpled for -4 rivets, so I can use -4 cherry's of similar or greater strength of the MK-319's.
Thanks again.
Larry
03-24-2014, 12:28 PM
Originally Posted by lr172
......Even if they corrode over time, I still think that I am better off than what I had. ......
Larry
Dip the rivets into zinc chromate and install them wet...
Gil Alexander
03-24-2014, 02:32 PM
Good idea, Thanks!
