Old 03-12-2014, 05:04 PM
Keith Williams Keith Williams is offline
Default Float Bowl Gaskets
Last December I brought the RV12 back to my shop to do the Service Bulletins and mods that have accumulated. At the time I removed the carb float bowls to get the auto gas out of the carbs.
Now I am bringing the plane back to life. Over the winter the thin cork gaskets dried, warped and seem to have even shrunk a little. Is there a way to bring them back to life? Perhaps soaking in something to make them pliable again?
Keith Williams
Milan, IL
Built RV6 #756, 1989-99, flew until selling 5/2016.
Built RV12 #533, 5/2011 to 11/2012, flying
Old 03-12-2014, 05:54 PM
BigJohn BigJohn is offline
Why take chance? Order new gaskets.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 03-12-2014, 09:18 PM
newamiga newamiga is offline
I flew another 912 powered LSA up to Oshkosh from Colorado a couple years ago and had an experience that would certainly make me agree you should just replace those gaskets. We ended up with a pretty decent fuel leak from the left carb float bowl gasket. As it turned out we ended up diverting into Portage and found the leak before it was a huge issue but had to have a mobile Rotax guy come out and replace the gasket. The gasket was slightly warped. It is really simple to do as you know from already taking it apart. It is well worth the few dollars to replace them.
Carl
Private Pilot
Old 03-13-2014, 06:17 AM
Thanks John and Carl. I will be replacing them.
Actually, I was planning to order six or eight to have them around. Then I saw $16 each on the Lockwood site. That means over $100 for six?..my "this stinks" meter went off. (It also goes off when I see the over $7 avgas price at my local airport.)
Then I wrote the above note.
After some more research (back to my BMW motorcycle days and the Bing carb stories from those) I am planning to go to the reusable ones from Real Gasket in Tennessee. They are $8 for a set of two (their number RG1311254764).
That is, unless the wiser heads here think that is a bad idea.
Keith Williams
Milan, IL
Old 03-13-2014, 07:07 AM
Dave12 Dave12 is offline
These are very interesting, maybe Roger Lee could consider giving these a blessing? My Bings are at the a/p, could someone who has their carbs closer look at these and see if they appear to be the correct ones? Thanks Keith.
http://www.realgaskets.com/files/popups/popup173.html
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 03-14-2014, 12:56 PM
sandpiper sandpiper is offline
I just changed mine during annual of my CTSW. What you show in your link appears to be the same shape.
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 03-14-2014, 02:12 PM
mrt890 mrt890 is offline
I put the rubber float bowl gaskets on a couple of annuals ago and have had no issues with them. I got them here:
http://www.ebay.com/itm/Rotax-Reusab...bef062&vxp=mtr
MRT890
120042 RV-12
N112XP
Old 11-10-2014, 10:19 AM
peteohms's Avatar
peteohms peteohms is offline
I have purchased float bowel gaskets on ebay. They were good quality.
Pete
Old 11-10-2014, 12:06 PM
cactusman cactusman is offline
I just ordered the Rotax bowl gaskets from Real Gaskets in TN....they do apparently swell a bit, but my plan for complying with the mandatory s/b is to buy two sets of these nitrile rubber gaskets, as the cork ones are disposable, weight the floats on my reloading scale, then when I repeat, let the old rubber gaskets dry out and put the rubber gasket spares in and so on and so forth, til Rotax comes up with a proper fix.
Note that for the bail carb type - you need the ones with the two holes - I don't think the single hole ones will work?
Old 11-12-2014, 01:00 PM
Loki Loki is offline
Use the regular fiber bowl gaskets. I have seen two sets of these rubber type gaskets over the last year fall apart. One was a good friend. He went to inspect his and they crumbled into his hand. Sometimes trying to save $5 isn't worth the risk. Bing uses the cork gaskets from the factory, but they don't seem to hold up, especially if you pull the bowl a time or two.
