02-04-2014, 10:23 AM
Originally Posted by LettersFromFlyoverCountry
Me too. The one time I'm conflicted, however is the "dive forward," which runs counter to taking weight off the nosewheel when taxiing.
Sorry for the confusion above, Bob. It is a bit counterintuitive to push forward if you are trying to protect the nosewheel. However, what you are actually doing by "diving away" (stick forward) with a significant tailwind is taking some weight off the nosewheel. With the stick forward in a tailwind, the elevator is being pushed down by the wind, thereby decreasing the weight on the nosewheel. If you didn't use down elevator the wind could get under the tail, pushing it up, and thereby putting more weight on the nosewheel.
Make sense?
This is one of those cases where you need to use your judgement. If the tailwind is very light, it's probably better not to "dive away" because, in that case, you would simply be adding weight to the nosewheel. It doesn't matter if you do that in Cessnas, but it might in an RV on rough ground. I don't know.
Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
02-04-2014, 10:51 AM
Yes, and I also realize I've been doing it wrong... again, partly because of my obsessive desire to taxi with full stick aft.
02-04-2014, 10:52 AM
seems to me that in trying to swing the tail into a very strong tailwind the vertical stabilizer is going to offer the most resistance. by pointing the rudder into the wind the area of the vertical stabilizer would be reduced, and certainly you would want it straight as you turn directly downwind.
does anyone know of any incidents where an RV got flipped in the wind?
02-04-2014, 12:41 PM
It all depends on the relative wind over the tail. If your taxi speed is greater than the tailwind, the relative wind moves front to back, and aft stick pushes the tail down and the nose up. If the tailwind exceeds your taxi speed, the relative wind is from back to front, and the control action is reversed; forward stick will push the tail down, nose up. Same logic with the ailerons-hold the upwind wing down with normal stick movement when the relative wind is front to back, but reverse the stick when wind is back to front.
02-04-2014, 12:53 PM
Of course you are right, Bob. I would add one additional factor. Relative wind also depends on how much prop slipstream is involved, ie. how much throttle one is using during taxi.
Thus, I think the long and short is that the natural inclination to adopt and teach arbitrary rules is a bit simplistic. It depends on whether you are tailwheel or nosewheel, what the relative wind is doing, what you might need to do to protect a nosewheel, etc. As my former Alaska bush pilot/tailwheel instructor commented to me, one should use whatever control input is necessary to keep the tail down and the wings level. That's all.
Steve M.
Ellensburg WA
03-13-2014, 08:41 AM
Last month I was in 35-40 mph winds in my 6. Normally I?m a fair weather flyer, and sure was pleasantly surprised how well it handled the winds while taxiing. It showed no tendency whatsoever to try to lift a wing.
03-13-2014, 09:21 AM
Full confession time ....
Me too.
I've taxied in x-winds 20G26 ... that big sail on the aft end of a Nine makes it quite interesting. Took a lot more lateral braking control than I had figured. There was, however, no tendency toward wing lift.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
03-13-2014, 11:04 AM
dont forget that the crown in the taxiway will work in your favor to help you steer right or left.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
03-13-2014, 07:40 PM
What's your max x-wind landing?
To the OP question, to my mind, the questions are:
what are the crosswinds now,
what will they be (with a healthy margin of safety) when and where I plan to land, and
what's my x-wind level of comfort?
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
03-13-2014, 08:00 PM
Am I alone or is the text so small due to the huge pic on page two here that reading the postings are, ahh, challenging?
PS Beautiful pic even if there is no RV in sight. :-)
