03-10-2014, 04:46 PM
45 or 90
I picked up a Desoutter 90 deg. drill while working in the UK 30 years ago. It has colletts for 3/32: 1/8th: and 3/16 in.
Two months ago I bought another 90 deg. Desoutter new from an estate sale for $30NZ.- not because to other was worn out but this allowed two different sizes to be available with out changing.
The very small head size compared to adapters that other use, makes this British product the best I have used.
The 90 degree type with a short drill makes the accurate drilling out of rivets very easy as you can roll the head to get a good centre, while supporting the drill body close to where you are drilling. These will do anything that a 45 and pistol models can do.
Look on UK Ebay for one- that's where they are made.
03-10-2014, 05:04 PM
90
I have a 90 and use it every once in a while. I have never seen a 45 and did not know that one was available till you asked about it and I Googled it.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
03-10-2014, 05:19 PM
Never used a 45. I like my 90 drill adapter though. I get to use it with the drill I like. 90 seems like a natural orientation to keep things squared up. Although, come to think of it, the 45 "may" be a bit better for the Horizontal stab SB if that's what you're thinkin.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
03-13-2014, 07:02 PM
I have a Dotco 90, and love it It has saved me several times. With a short bit, you can get into really tight spots and get a perfect hole. Expensive, but worth it.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
03-14-2014, 07:05 AM
Originally Posted by Ironflight
Every year when I fill out my Christmas list, I know I'd like a good angle drill, but I get stopped when I try and decide between a 90 degree angle and a 45 degree angle - they are expensive enough that I can probably only justify one.
Tell Louise you want a Jiffy modular:
http://jiffyairtool.com/site/wp-cont...12/catalog.pdf
But don't tell her it was my idea
Dan Horton
RV-8 SS
Barrett IO-390
03-14-2014, 07:13 AM
And...a 45 is a bit awkward. It's easier to drill out fasteners with a 90 as you can more easily see the correct angle. I've seen (and probably done so myself) people really booger up a hole with a 45.
Tony Phillips
N524AP, RV 9 (tail wheel)
03-14-2014, 09:03 AM
VAF Moderator / Line Boy
Thanks for all the replies guys. This just goes to prove the old adage about wisdom coming from experience - and if you don't have your own experience, get the wisdom from someone else's experience! I could see the potential pluses and minuses to a 45, but having not played with one, just wanted to probe the collective. I'd love to have the modular system there Dan - maybe I'll have to write something about angle drills and then I can write it off....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
