02-23-2014, 01:33 PM
Doing "the Fix"
It took forever to try and figure out what the drawing "Figure 7 (RV-8)" was trying to tell me.
The note about the 'rectangle' "Match-Drill #30 Then Cleco, 8 Places", is not a part. It is showing the eight holes that are to be drilled. Poor drafting.
This line should be something other than a solid line.
Next: Steps 17 & 19 are too many words for what needs to be done. I am sure that a picture would be worth a thousand words, but these steps not clear. Confusing. Mainly Step 17-4 (paragraph, that is) and then Step 19 - 2.
I have figured it out, but took too long.
Ed
Reason: spelling
02-24-2014, 08:50 AM
Originally Posted by Ken Martin
Step 13 calls out a final drill of the fwd most hole in the top and bottom flange of the main ribs. No problem, I bought some #27 bits. However, on page 19 of 20 in Figure 11, the rivet callout for this location is still AN426AD3-3. If this is the case, why increase the size of the hole from the original callout? What am I missing?
When you squeeze the -3 in the #27 hole you get a perfectly double flush rivet that expands just enough to fill the hole and hole the rivet in the exterior skin. That rivet is no longer holding anything just plugging the hole after the spar flange is trimmed away.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
02-24-2014, 11:05 AM
1992 RV6
~ 750hrs
- No Notches
- No Cracks
- 160hp/Wood Prop
- Some grass/some acro
02-24-2014, 06:47 PM
Just finished my SB on RV8 that is under construction
I was just about ready to mount my HS on my 8 QB. I decided to just go ahead and do the SB. Since I did not have to remove the HS it was just the repair. Total time was 22 man hours. Not quite as bad as I thought it would be. It takes a while to understand the directions. The hardest part was drilling out the -4 rivets inside the spar.
If I knew how to post pictures I would do so.
02-24-2014, 06:52 PM
See: http://www.vansairforce.net/articles...ums/images.htm
Arlen
Donation to VAF 10.29.18
RV-6, February '14, SOLD December '15
02-26-2014, 09:38 PM
after talking with an engineer at van's who was repairing the cracks on his -7 at the time, he said the finite element analysis program clearly showed a fatigue problem on the forward spar and that the fix he engineered was strong enough to handle the spars loads all by itself. apparently [my understanding of what he said] when loads are placed on the spar the top edge wants to act like a hinge, since the bottom is bolted to the fuse, and moves forwards and back, bringing on fatigue. he said about 15% of the high-time planes were having cracks.
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
02-27-2014, 04:04 AM
What is the explanation for the cracks on the low-time aircraft?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
02-27-2014, 10:52 AM
I didn't ask. our meeting was the first I had heard of it. I was giving him a hard time about how much he[an engineer] works on his plane compared to me[a carpenter]. so, this carpenter needs to do some inspections soon, because I have 1600+ hrs and used to fly aggressively.[like 5G stalls messing with an AOA meter for instance].
2014 - PAID
02-28-2014, 09:56 AM
1994 RV-6A
Empennage slow-built in '94.
No notches, no cracks found.
O-320 160hp FP Sensenich
almost all ops on turf, mild acro. 890 TT
Like most 16 year old RV's, she's showing age elsewhere - but not in the elevator spar :-) We did discover three loose jam nuts, two on the elevator and one on the rudder. No cracks there, either.
-Bill Boyd
02-28-2014, 02:56 PM
RV-8
Tail kit 2003
First flight 2010
~200 hrs.
Some aerobatics
No notches
No cracks
