02-20-2014, 10:47 AM
AN822-6-6?
Having a hard time verifying if I ordered the correct steel fittings. Is the fitting below an AN822-6-6? Thanks, Gary
Gary K. Bacon
RV7A, IO-375, CS Prop, Dual P-Mags, Classic Aero Interior, Sam James Cowl & Wheel Pants, 3-G3X, GTN 650, GTR 200, Garmin Autopilot & GMC 305 Contol Panel, VP-X, and more...
Airworthiness & Repairman Certificate Issued
Phase 1, Completed  120 hours and counting!
02-20-2014, 12:42 PM
I believe what you have there is an AN822-8D, (or an MS20822-6D) which is 1/2" tube to 3/8 pipe. Tube sizes are measured by OD, while pipe sizes are measured by ID.
RV-7 TU 904KM (reserved)
Construction Log
02-20-2014, 01:54 PM
Nomenclature for fittings?
Well, if you're right then I ordered the wrong fitting. I can't find anything on the net that clearly states what it is. If I look at the chart on skygeeks, it says I need a MS20822-6-8, assuming the tube is the outside diameter and pipe thread is the inside diameter.
Gary K. Bacon
02-21-2014, 12:12 AM
Originally Posted by TangoPapa
You are correct that the OP's photo is of an aluminum fitting, but he wants to replace it with steel. However, original poster 's photo shows the flare as 3/8 ID. Tubes are designated by OD. I use http://www.gen-aircraft-hardware.com...f/ftgnpt37.pdf as a reference. It refers to any 3/8 pipe to 1/2 flare a-8 size.
Construction Log
02-21-2014, 10:07 AM
The OPs image is not a 1/2 NPT pipe (as proven by the 18 TPI dimension)
Therefore it is not an 822-8D.
What remains is 3/8NPT x 3/8 Tube flare or 822-6-6D
EDIT: Never mind, I misread the table columns on a too small mobile screen. As stated below, both -8 and -6-6 have a 3/8 NPT. The dif is tube size.
Bill Pendergrass
ME/AE '82
02-21-2014, 12:59 PM
Therefore it is not an 822-8D...
Not necessarliy. Check the tables... both -8 and -6-6 pipe to flare adapter fittings have a 3/8 pipe size.
I may have been wrong about the tube end size, so Gary, you may have ordered the right fitting after all. Measure a fuel line fitting tube end I know they are 3/8.
Construction Log
02-23-2014, 09:29 AM
Tomorrow - Monday delivery
I'll find out tomorrow if I ordered the right fitting. I called spruce and they said to size it up to actual scaled picture in their catalog. I don't currently have a catalog but I did down load a PDF file which helped a lot. So I did change my order to an AN822-8 steel. I'll post tomorrow, right or wrong. Thanks for the help! Gary
Gary K. Bacon
02-24-2014, 05:16 PM
AN822-8
AN822-8 is the correct size!
Gary K. Bacon
