02-17-2014, 04:36 PM
Gear tower mod
I'm planning on doing the gear tower mod (screws and cover plates) mentioned in other posts ... what I have not seen mentioned is how those of you with QB fuses cut the web out with everything installed in the fuse.
I was thinking a Dremel with a cutoff wheel or perhaps a nibbler, but before I start hacking into things I thought I'd check to see if anyone had a brilliant / easy / safe way to do it.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
02-17-2014, 04:43 PM
I drew a line and cut with hand shears then filed to finish. Probably the quicker way to remove the material.
Randy Hooper
RV-8
N84H
02-17-2014, 05:10 PM
I used a dremel
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
02-17-2014, 05:49 PM
+1 with the aviation snips, L and R handed. Then finish to the line with a file.
RV-8 FB, S l o w Build,
180FI, Catto,
Australia.
02-17-2014, 07:18 PM
Jigsaw and a file.
Dan Horton
RV-8 SS
Barrett IO-390
02-18-2014, 06:06 AM
Originally Posted by DanH
Jigsaw and a file.
Thanks!
I've got some fine metal blades for the jigsaw ... this goes under the "why didn't I think of that?" tab.
Thomas Short
02-19-2014, 05:20 AM
May not be a consideration in your case, but the base on my Jigsaw was about 2 3/8" wide. Which would have left a lot of filing, or creeping up with the snips anyway. (The final cut line was less than an inch from the rivet heads)
Don't know about the quicker/best method, but it was easy, safe, and left very little swarf/mess with the snips.
Paul.
(Before final cuts.)
180FI, Catto,
Australia.
Reason: reduced image size
02-19-2014, 07:27 AM
Snips & file
William Slaughter
Houston, TX
RV-8QB
02-19-2014, 08:55 AM
Die grinder with a cut off wheel here. Took longer to mark it than it did to cut it. It's only an airplane..get in there and build it.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
02-19-2014, 05:45 PM
Has anyone made the modification on a flying RV-8?
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
PAID 2021
Pittstown, New Jersey
