  #11
Old 10-17-2011, 07:51 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Originally Posted by N941WR View Post
If he has a key switch, he will have to ground the plugs. If he used mag switches and a starter button, then he can just leave the mags off.
I do have a key switch. What is the easiest and safest way to ground the bottom plugs that I remove?
Or, could I leave the key off and jump the starter and not worry about grounding (assuming I don't have a hot mag, which last time I checked I didn't...)
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 10-17-2011, 07:53 AM
ao.frog ao.frog is offline
Default Another item (ref post above)
Charge the battery....
This schould ofcourse be done beetween pt 3 and 4.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 10-17-2011, 07:59 AM
ccsmith51's Avatar
Thanks for the suggestion. The battery (Odyssey) has been on a trickle charger the whole time I have been gone, so I expect (hope) that it will be charged and in good shape when I get back..
Chris Smith
Old 10-17-2011, 08:04 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default There is more you can do
I agree with the above comments completely, but there is more you can do. The first minute of start up is where parts are dry from sitting and most of the wear occurs. I agree that spinning the engine to get the oil moving is a wonderful idea, but.
You can completely fill your crankcase with oil, then with sparkplugs out, rotate the prop for many turns. This has the cam and cylinder walls completed covered in oil while the parts are rubbing together. Then drain the oil. Refill with proper amount and go fly. I have never seen this printed anywhere but I have done it and felt good about it. YMMV.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-13-2014, 03:40 AM
Dr107flyer Dr107flyer is offline
Default Dry start up advice
Searching for advice on starting after a prolonged period of inactivity and came across this. Has anyone tried filling the crankcase completely with oil as mentioned below ?
Old 02-13-2014, 10:16 AM
edsong's Avatar
edsong edsong is offline
My Pitts(IO-360) sits for 5 to 6 months in the winter. When it gets warm enough to fly March-April I start it up and fly it home. I don't think these engines are that fragile that you can't just start it and fly.
EDDY
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 02-13-2014, 10:32 AM
Toobuilder's Avatar
Considering the cam takes the biggest beating at startup and is also completely dependant on "splash" lubrication, you want 1000+ RPM ASAP. Grinding on the starter may float the bearings, but your cam is dying with every dry turn.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-13-2014, 11:12 AM
Yes I know it's splash lubricated but I was wondering about the idea of filling the case with oil to lubricate the cam before attempting a start ?
Old 02-13-2014, 11:19 AM
N54SG N54SG is offline
EDDY
I'm with you on this. If these engines were as fragile as everyone thinks they are, they would never work for the average Cessna or Piper owner.. Just be smart about it, and start the **** thing, in my opinion. I think oil on the cam is the one thing to think about, and all the cranking in the world won't help that. I assume an advantage of roller lifters, like I have, is less wear when 'dry'.
Lancair 360
Best Race Speed: 279.686 mph
Building Lancair Super Legacy
LaminarConsulting.com
N54SG.com
Old 02-13-2014, 11:26 AM
DanH's Avatar
DanH DanH is offline
You can't, at least not quickly.
Dan Horton
RV-8 SS
Barrett IO-390
