  #511
Old 02-11-2014, 01:52 AM
Richard Connell Richard Connell is offline
Default No Cracks - Both SB's
RV-7 S/N 72555
Completed AUG 2009
400 TT
IO-360-M1
Hartzell BA
Lots of grass.
Lots of short rough strips.
Some Mild Acro
Notches per plans - I remember doing a second set of front spars as wasn't happy with the first notches circa 2005.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-11-2014, 10:29 AM
dabney dabney is offline
Default Guessing about whether other owners can detect cracks or not
"I would hazard a guess that many who reported no cracks are simply not seeing an obvious crack and moving on."
This comment was made a couple of replies ago.
Really?
I do not agree with your hazardous guess. I think RV owners after reading the extensive comments on this subject know where to look, how to look, what to do to prepare the surface for inspection etc, particularly after some earlier comments that some of the early inspections did not detect a "not so obvious" crack. Many owners are bringing an extra set of eyes into the inspection process, photos, magnification, borescopes etc to ensure any "not so obvious" cracks are not missed.
My a/c luckily did not have any cracks but I could post the pictures I took to prove it, if I knew how.
Paid for 2020 and well worth it!
Best investment I make all year....
US Army 1st Cavalry Division OH-58 AO
LAPD helicopter pilot, retired
RV6A sold
RV12 (non-builder)
Old 02-11-2014, 12:06 PM
JonJay's Avatar
JonJay JonJay is offline
Really?
Yes - really. This comment came after I assisted in an inspection AFTER, they had already reported "no cracks". They are removing the paint now to re-inspect. I do not expect them to find anything..... their build is top notch.
I did not "hazard" a guess, so I should not have worded it as such, and I should not have said "many". I certainly did not mean to offend you or anybody else.
From my past experiences, RV owners are not much different than anybody else, and with the long, long posting, it would be very easy to miss the prior comments you mentioned.
If my comments send one person back to inspect and that one person finds something different, it was worth reminding people.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-11-2014, 01:10 PM
n747jg's Avatar
n747jg n747jg is offline
Default No cracks
N747JG RV-8
No cracks (close-up HiRes photos)
No notches
Mild acro, less than 4 g's
Paved runways
590 hrs TT (first flight July 2008)
Lycoming (Barrett) I0-360-X 215 hp 10.1 pistons
Dual P-Mags
WhirlWind 200RV CS prop - professionally balanced
Regularly back the airplane and steer into the hangar using the empennage
Jim Gray
www.rmrairshows.com
Old 02-11-2014, 01:13 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
Default Starting over
I had a twisted aileron and tried to drill out the rivets to save the skeleton but after a few rivet holes enlarged I threw it all in the scrap aluminum pile in the corner and ordered a complete new aileron kit. I do feel for you all who find the cracks in the H.S. parts. I felt the worst part was re-painting.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
Old 02-11-2014, 02:37 PM
bret's Avatar
bret bret is offline
I have no cracks....or flt hrs, still under construction, but still, I drilled mine all apart this weekend and waiting for the parts to come in. No rivet holes were harmed. 4 Hrs
Old 02-11-2014, 05:24 PM
kblack kblack is offline
Default Thanks!
Building a 7. And I am the 3rd owner of a 6 purchased last summer with about 1,000 hours. My understanding is the builder worked for Gulfstream and used their paint system. Beautiful craftsmanship and paint (very tough) throughout - including on the parts that require inspection.
I was stumped on how to proceed, but posts to this thread clued me in. Planning to use Methylene Chloride based stripper (nasty, but won't harm aluminum), Q-tips, and plastic or wooden scrapers to remove the paint for a proper inspection with a magnifier or camera (borescope). I will report back with results.
Kudos to Van's for their quick follow up to develop and publish these SB's. And a special thanks to RVBuilder2002 (Scott) for his hard work to keep up with this forum, and for his patient and thorough answers to the sometimes "tedious" questions and comments. Keep up the good work!
While I'm at it, I can't say enough about this website and these forums. Way to go Doug Reeves for having the vision, skills, and tenacity to make it happen!
Kliff
Granbury Texas
RV-7 QB (N74KB) - Flying
RV-10 QB - Empennage Started
Old 02-12-2014, 06:18 AM
dilamipo dilamipo is offline
Thumbs up No Cracks
I-RVBL RV-7
No cracks
notches as plan
Mild acro
Paved runways 10% , Grass 90%
110 hrs TT (first flight April 2013)
Lycoming 0-360-A1a
Hartzel-Tonini CS prop - professionally balanced
Dimitri Paolacci
Italy
RV7 tip up sold
RV7 slider flying!!!
www.rv7.it
Old 02-12-2014, 07:04 AM
Robski Robski is offline
Well stop it, then!
Use the tailwheel / spring, either in your mitt (I do) or via a tow bar!
The spring is designed to take the weight of the aircraft, in side loads as well as vertical ones.
Just because RVs are tough as old boots there's no need to treat one like an old boot!
Rob Swain.
If the good Lord had intended man to fly, He would have given him more money.
1994 RV-6: bought 2008 & improving it ever since.
Old 02-12-2014, 08:42 AM
49clipper 49clipper is offline
Default 49clipper
No notches, no cracks, 325.0 hrs/light acro, less than 3.5 g's, RV-6, O-320,
90% grass.
so what is the tally so far on cracks?
