Go Back   VAF Forums > Model Specific > RV-6/6A
Old 02-06-2014, 05:28 PM
6adan 6adan is offline
Default EGT probe with Vetterman exhaust
Hi, new here been reading a lot but now have a question about my 6A I am building. I am putting a Dynon Sky View in, I have the engine probe kit but am not sure where to mount the EGT probes in the pipes because of the bend or welds in the pipes in the area where Dynon say they are supposed to go. Anyone have any pictures or info on where they put the probes.
Thanks Dannie
Old 02-06-2014, 05:33 PM
posterman posterman is offline
Default EGT probe location
Best I can recall without pulling the cowling is that the probes are located two inches or so, below the exhaust gaskets...it's been awhile but the probe manufacturer may details an acceptable range.
Old 02-06-2014, 05:47 PM
BillL BillL is offline
Do you have your exhaust system already?
My AWI system came with holes already drilled about 3" from the bottom of the mounting flange. It has swivel joints that prevent mounting closer. Does Vetterman have them predrilled too?
Here - Look at Jasons, they are a little higher than the AWI.
http://www.jasonbeaver.com/rv7/2010/...-temperat.html
Bill
RV-7
Lord Kelvin:
Old 02-06-2014, 05:51 PM
Super Moderator
Default Make them all the same
It's no much important as where they go as it is that they should all be the same distance from the exhaust flange. So, look for your hardest one to mount, and then match the others for distance.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 02-06-2014, 06:01 PM
GLPalinkas's Avatar
First, WELCOME TO THE GOOD SHIP VAF. Can't believe I beat Mike S. He must be napping in his easy chair. He's getting old....
Second, what Vic said. Most important that they are equal in spacing from the flange. I'll try to find a photo of mine (EI probes but the concept applies)
Found an early pic. I was working on baffling, I think but you can see the probe placement. It's been working great for 250 hrs.
Venice, Fl
Old 02-06-2014, 06:11 PM
Bill the pipes are not drilled and my understanding was they needed to be 4'' to 6'' below the flange and on #3 there is not that much room. I was not sure if I could go closer without causing some kind of problem. Vic do you thank it hurt anything to go closer to the flange, I thank I can only get about 2" to 2 1/2''.
Dannie
Old 02-06-2014, 06:19 PM
GL thanks for the pic that is what I needed. You must have been typing the same time I was. Looks like a couple in. from the flange would not be a problem.
Dannie
Old 02-08-2014, 06:00 PM
I just found out that I have the Vetterman with 1 1/2 in. tubes instead of 1 3/4 in. tubes. When I saw GLs picture I knew something was different.
Old 02-08-2014, 06:33 PM
Super Moderator
Default That's OK
Dannie, soprry I missed this. You will be OK at 2 to 2.5 inches. I think that is where I have mine.
Vic
Vic Syracuse
Old 02-08-2014, 11:46 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Here's our RV-6A, Vetterman Exhaust (late 90s), at 1.5 inches from the flange. Before you drill, check the orientation of where the head of the hose-clamp will be for ease of access (remove and replace) Rosie & Tuppergal
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
