Old 01-31-2014, 01:26 PM
9erDriver 9erDriver is offline
Default Cut & Buff believer
I was singin' the orange-peel blues after spraying the bottom of my RV8A fuselage with Deltron DCC Concept topcoat (over DP epoxy primer). So with nothing to lose I tried Dan Horton's Cut & Buff methodology using the 3M products he recommended: trizak 1500 wet color sand with DA sander followed by 2 stage buffing with electric buffer using the 3M #1 and #2 rubbing and machine polish compounds.
I am astonished - this stuff really works. My amateur paint job turned into something very acceptable. I highly recommend this for DIY painters wanting to achieve a near-professional finish.
Thanks, Dan, for posting this advice.
Steve Pofahl
A&P Mechanic - KBKX Brookings SD
RV8A N84ME flying
RV9A N249ST sold
RV14A - build in progress
Old 01-31-2014, 02:18 PM
I've used DanH's technique several times, and not always on an airplane ...
.. it really works. I love that he shared the process so thoroughly and with such clear and easy to follow steps.
FYI: here is the DanH thread.
Old 01-31-2014, 07:40 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Great looking woodwork!
Old 02-01-2014, 04:54 AM
Thanks. The technique DanH describes in his thread works in lots of cases. I couldn't quickly find any of my metal work.
I did find my video of a propeller I refinished using DanH's tutorials ...
http://vimeo.com/m/50006571
... and description of the process ...
http://thesalmonfarm.org/blog/p/3395
One of the tips (or tricks) that make a difference is the "sanding blocks". I had some old 2" high density closed cell minicell foam (we use to use rasps and dragon skin to contour it for kayak seats). Anyway, the foam will give a little but only with significant pressure.
I glued my wet sandpaper to these foam blocks - 400, 800, 1200, 1500 grit. Using a misting water bottle, these blocks work great and I see high spots / low spots just as DanH depict in his thread.
I keep an eye out for that foam but I've not stumbled across it since my whitewater boating days. (Probably because I don't know the correct name of the material.)
Old 02-01-2014, 07:56 AM
DanH's Avatar
DanH DanH is offline
Glen, that is beautiful woodwork.
With talents like that you need to build an Albatross D.V. This one was built for Frank Ryder (RIP) and now lives in Belgium.
http://www.stampe.be/UK/The_Collection_Albatros.html
Think how much fun you could have, orbiting in the sun, waiting for the Russian...
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-02-2014, 11:55 PM
SvingenB SvingenB is offline
I have been experimenting with some similar things myself, but have not really made it to the finish line regarding the end result. I am probably using the wrong techniques/products/procedures. Where can I find Dan's recipe ?
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
Old 02-03-2014, 06:46 AM
Hi Bjørnar,
I have it above but here it is again (it's that good a thread it deserved repeated links) DanH tutorial on cut and buffing paint.
Dan, I'm working on a project that is about 2-1/2 decades younger and a bit larger
Old 02-03-2014, 08:05 AM
broken1234 broken1234 is offline
Compared to other brands, I have had some trouble getting the dried 3m products out of the rivet heads after buffing is complete. Did you guys have any problem here?
Brad
Old 02-03-2014, 08:27 AM
Brad, I use water and had no big issues. That said, I am careful and gentle around the rivets.
Old 02-03-2014, 01:13 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Very nice looking Cherry wood Glen (:-))
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
