Old 02-02-2014, 03:10 PM
Decided to let it ride and not fix something that's not broken. Went out to hangar today (-7.at sunrise,) and spent a couple hours putting the elevators back on (all new hardware of course) I sure love squeezing in all those washers aside rod end bearings. Yeehah.
I'll put the VS on tomorrow and then make the rudder bottom fairing change to get rid of the snap bushing for the tail light and widen out a slot. Found too much chafing on the wiring.
In the meantime, it all gave me an opportunity to go over the the rudder, VS, and elevator with a fine inspection to get the progressive annual underway, I've been meaning to move it to too-cold-to-fly season anyway.
I'll plan on buying some HS parts from time to time over the years and slowly build a second HS. If the cracks appear, I'll just swap it out. the longeron attach point redrill isn't an issue. The shim makes a good drill guide .If I sell the plane, it'll be a relatively inexpensive A&P bill for the next owner.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 02-02-2014, 03:17 PM
SebsRV7A SebsRV7A is offline
Default One Crack! Top left side
Did the inspection this afternoon. One crack in the top left corner. Bummer!
RV-7A
635 hours
A little acro
A good bit of formation flying
180 HP Constant Speed Prop (Whirlwind composite)
Notches per the plans
Fewer than 10 grass landings
Seb Trost
RV-7A
Boulder City, NV
Old 02-02-2014, 03:22 PM
jroser jroser is offline
14.3%
Time for a margarita and football. Anyone feel free to pick up our running tally.
Old 02-02-2014, 03:24 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
I'll add another one.
Inspected a friends RV-6A, low time since a TX rebuild after a flip-over.
New horizontal bought pre-built.
Low hours on the new horizontal -
No cracks seen, and the hardest part of the inspection was removing the tight fitting HS-VS fairing.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-02-2014, 03:35 PM
hudgin hudgin is offline
Who do we contact for warranty? I think that these being a homebuilt nobody had to say anything about this. Thanks to Vans for their integrity. The integrity now has to follow on with the owner. I'll look at mine when it isn't so cold and wet.
member 1 of 6
Metal Feathers Club
RV 7 N706CB
1st flight Oct 18, 08
S/N 72847 tip 200HP CS glass IFR
Old 02-02-2014, 03:50 PM
mike newall's Avatar
mike newall mike newall is offline
We are doing the inspection on Tuesday.
No cracks found......
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 02-02-2014, 03:51 PM
BillL BillL is offline
Originally Posted by jroser View Post
Hello everyone,
A quick tally on the numbers so far listed on this thread:
Cracks found- 5
No Cracks - 40
11% so far on finding cracks in the hs
I will be checking my 6a tomorrow to report back.
John
My count is 8 with Danny King being the first -8. I am making a list with hours to make a failure probability plot.
2-6's
4-7's
2-8
Considering 5000 planes flying this number is extremely low, not to mention the crack is a soft failure, and no incidents are known in the fleet. One would have thought the 6's would have more hours and be higher in the reporting, but not yet. The population reporting here must be quite limited. Surely it will unfold with time.
posts go too fast to update the count!!
Bill
RV-7
Lord Kelvin:
Old 02-02-2014, 03:54 PM
I did not include the factory 7.
Old 02-02-2014, 04:11 PM
steveflys steveflys is offline
Looked at mine today no cracks
rv-6
tail built 1995
first flight 2000
0-320 c/s
1061 hours some acro
Steve Searle
Creswell Or
Old 02-02-2014, 04:12 PM
RV6Danny RV6Danny is offline
Thumbs up No Cracks Found
Inspected today per S/B 14-01-31
No Cracks
No Notch's
1995 RV-6, 715 Hours
0-360, 180HP
Constant Speed Prop
No Arco
Mostly paved, some grass
Danny
RV-6 N360DP
