  #21
Old 01-20-2014, 12:16 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Originally Posted by spaceflightmeow View Post
Holy cow, FL-mike, you win the thread. Excellent data. What is the significance of most of the energy being at the prop frequency? My guess is that it prop noise would be acoustic noise, penetrating through the drum-head firewall and also beating down on the canopy.
The blade pulses on the windscreen and exhaust pulses on the floorboards?
I think each cylinder fires every 180 degrees, so that is the same as a two blade prop blade frequency. 2*2700/60
Mike W
Venice, FL
N164WM
Old 02-02-2014, 10:41 AM
Vansrv7arob Vansrv7arob is offline
Default muffled exhaust
Just put my order in for a muffled exhaust from vetterman, larry said it will reduce noise by approx 6db wbat else was interesting was when they dyno the new 1.5 vs 1.75" crossover system the 1.5 came out in front in hp accross the range? Huh...anyway i'll give it a go.
I like the data just makes arguments so much simpler....
Regards,
Rob.
................__|__
......______(-o-)______
M: (61) 401 578 700
