Old 01-30-2014, 10:45 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default FYI: Exhaust radiant heat
Yesterday doing a dyno run @ G3i facility on a new concept exhaust system for ?Vetterman Exhaust Systems?. At 100% power the pipes started to turn cherry red @ 1300f and lean for peak power 1440f bright red/orange. Should of flip the lights off for moment, would have been a good pic. We took a few pics of it for the curious. The example shown is to make aware of the radiant temps that are inside the cowl and components are subjected to. That?s all?.Go Bronco?s
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
Old 01-30-2014, 11:17 AM
rocketbob's Avatar
It would be really interesting to see what happens to CHTs if one has the insides/outsides ceramic coated.
Easier said than done on used pipes.
Its nearly unheard of in the racing world to run uncoated pipes.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-30-2014, 11:26 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Just a curious thought as I have absolutely no prior knowledge, but wouldn't air moving through the engine compartment keep those pipes quite a bit cooler?
It seems that in a test cell you likely don't have that kind of airflow over them. ??????
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 01-30-2014, 11:31 AM
bkthomps bkthomps is offline
even on air cooled engines?
Old 01-30-2014, 12:49 PM
Doug Rohrer Doug Rohrer is offline
Default Cool!
Aircraft glow underlighting!
Doug Rohrer
Bowling Green, KY
Old 01-30-2014, 04:22 PM
hohocc hohocc is offline
Default Ceramic coatings
On the Vetterman exhaust website there is a paragraph under FAQ entitled "How about ceramic coatings", implying they keep heat in the head. No numbers quoted though.
Old 01-30-2014, 04:46 PM
BillL BillL is offline
When I ran a dyno in the lab, one day my cell neighbor (common control room between cells) was running maximum power at peak torque ( diesel past regulated fuel) and it was about 1400F for a while getting the data point. I know it was not true, but I swear it looked like you could see the turbine wheel turning through the housing.
Neat stuff, and reminds us why we have shielding FWF for critical things that don't like to be hot.
Thanks for sharing!!
Bill
RV-7
Lord Kelvin:
Old 01-30-2014, 06:00 PM
Toobuilder's Avatar
Originally Posted by BillL View Post
?... I know it was not true, but I swear it looked like you could see the turbine wheel turning through the housing....
Yep, we used to see that with the mighty J-58 too...
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-30-2014, 06:44 PM
Charles in SC Charles in SC is offline
I used to have occasion to fly a Piper Navajo. A section of the exhaust was visible through a vent on the side of the cowling. After dark this would glow pretty good even at altitude in cold temps. I do not know if it was any special metal or not. I think some of the Cessna twins had their pipes made out of iconell or something special to stand the heat but I do not remember hearing that about the Pipers. There is a lot of heat there for sure!
RV 7
Old 01-30-2014, 07:25 PM
Gisnar Gisnar is offline
Do not want to hijack this thread (if this question needs to be moved great!).
But, what has been the experience with ceramic coatings and wrapping the exhaust on our little piston engines?
