Old 11-14-2006, 08:09 PM
airguy's Avatar
airguy airguy is offline
Default engine pre-oilers
Does anyone here use the engine pre-oiler devices to supply oil pressure to a cold engine just before start? I've seen two basic types, an electric pump and an accumulator style. Do they work well enough to be worth the weight and complexity? How would you even know without running to TBO and tearing down?
Old 11-14-2006, 10:14 PM
Mel's Avatar
Mel Mel is offline
My opinion (yes I have one occasionally) is that pre-oilers are not that great. Yes they help, but the primary thing in a Lycoming that needs pre-oiling is the cam lobes. A pre-oiler doesn't do this. The cam lobes are oiled only by "splash" with the engine running.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-15-2006, 04:40 AM
mahlon_r mahlon_r is offline
Unless you modified the crankcase and installed oil nozzles to squirt oil on the cam lobes during build up. Then during the pre oil procedure and during operation the lobes are being pressure sprayed rather then relying totally on splash.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk.?
Old 11-15-2006, 07:32 AM
pierre smith's Avatar
Default Fly more
Hey guys,
Just fly more and the lobes will stay wet!
Seriously though, my late boss had a P-51 which ate cam lobes since they ran directly on top of the rocker arms. After he started adding 10% STP, the lobes lasted and lasted and...since it doesn't evaporate/drip off like 20W50.
Mahlon, is 1 pint of STP OK in a 4 banger Lyc?
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-15-2006, 08:15 AM
Walter Atkinson Walter Atkinson is offline
Since the vast majority of wear occurs in the first 30 seconds of startup, pre-oiling cannot do anything but help. It would be nice if this included the cam lobes, but it doesn't. It still is a very good idea on airplanes that are flown infrequently. If you fly at least once a week, I'm not sure it would make much difference.
Walter
Old 11-15-2006, 07:25 PM
penguin penguin is offline
So roller followers are a good idea?
Pete
Old 11-16-2006, 03:32 AM
captainron's Avatar
captainron captainron is offline
Originally Posted by pierre smith
Hey guys,
Regards,
Pierre, technically, STP is a "viscosity index improver", which just means that it raises the viscosity of whatever oil is mixed with it. One of the products that I used on new engines is sold by GM called Engine Oil Supplement, or E.O.S.. General Motors found it protects cam lobes from wear during engine break-in. This is a reason you shouldn't change-out the factory oil too soon after you buy a new car. I don't know if it's still used since everything has roller cam-followers now.
B.T.W., how much STP did he add to the P-51? Our T-28 holds 16 gallons of oil; the Mustang is probably more!
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 11-16-2006, 05:07 AM
Default 10%
Hi Ron,
Jack Sliker (my late boss) added 10% of the total oil as STP. I also used it in my T-6 since I saw the difference it made in his -51 [which Wiley Sanders, (Troy, Alabama) bought.]
I don't remember the amount because I don't recollect how many gallons the Mustang held. The year was also 1975, so time helps Senioritus set in too
What a difference 30 years makes....my son's Honda Element calls for 5W-20 year 'round!
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 11-16-2006, 05:42 AM
captainron's Avatar
Hi Ron,
Regards,
This is one of the disappointing things about roller followers in the aircraft engines,-that they can't take advantage of lighter weight oils for less internal drag and better fuel economy. I'm seriously looking at the ECI engines with oil nozzles instead of rollers.
Fewer moving parts, reduced chance of something coming apart, etc..
I'm sure rollers are tested and "almost" bulletproof, but if that one roller pin walks out, or if the little locating pin in the grove on the follower body breaks, you will have bigger engine problems than just worn cam lobes.Time will tell, and we have asked for change..... Lycoming thinks they are okay.
Ron Leach
Cincinnati
.....Bob Seger
Old 11-16-2006, 08:01 AM
Default 20W50
I curently use 20W50 Philips in the 6A.
Back in the eighties when multigrade aviation oils came out, I was flying a Cessna Agtruck with an IO-520 Conti that had Cermichromed cylinders and they recommended Philips 20W-50 and so I started using it. I could not believe the drop in oil consumption and how clean it was after 33 hours (we changed at 3 times/100 hours) running the engines at 25" X 2500 RPM all day long hauling 200 gallon loads.
Since this was exactly what I saw and flying 400-500 hours a season in 100 degree temps sometimes, hauling heavy loads, I was sold on the oil and the reason I use it today.
The PT6-15 in my Air Tractor uses Exxon 2380 synthetic oil and it gets changed once a year around 400 hours and is as clear as water then. (1000Hrs is usual)!! That oil is as thin as water, yet the CT wheel spins 37,500 RPM at 100% and runs all day long at 95-97% of that!
Sure wish we could run synthetics in the Lycs. But I've heard that if you have a small oil leak with regular oil, you'll have a major one with synthetic. The shear strength of synthetics is far superior to dinosaur oil and I'd bet the cam lobes would go forever.
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
