Go Back   VAF Forums > Model Specific > RV-9/9A
Old 01-22-2014, 07:02 AM
ka6dan ka6dan is offline
Default tubing routing more precise ?
What is the trick to routing the AOA and pitot tubing from the instrument panel to the wing root. Specifically for RV 7's and 9's. My original question was not adequate to address my current activity.
Also where can one find green or blue 1/4" tubing
Ka6dan
RV9A
Phase I @ X35 is complete
Paid My 2020 dues. 😃
Old 01-22-2014, 07:30 AM
airguy's Avatar
airguy airguy is offline
1/4" nylon tubing in the plumbing department at Lowes or Home Depot. It's almost as flexible as a wire bundle, just route it wherever it makes sense and don't kink it.
Old 01-22-2014, 07:33 AM
RV9A Bill RV9A Bill is offline
Default Safe air
I used connectors and tubing from safe air that I bought through Avery.
Bill
Old 01-22-2014, 10:55 AM
Rupester Rupester is offline
Default Stein
Stein sells colored tubing and high quality press-click fittings for pitot and static piping.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-23-2014, 08:27 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Similar to wiring
I used 1/4" poly tubing from Lowes Aviation and routed pitot through sub panel, down firewall with wiring, under the center tunnel, across the front of the center spar section with the brake line, then through the hole in center section to the wing root.
Also ran AOA from wing root through the snap bushing at front of seat ribs then under floor panels and baggage area to ADHARS behind baggage panel. If it was going to panel, I could have run it through wiring holes in center section near the tunnel. Just need enough radius turn to not kink tube, or use 90? fitting if you can find one.
Good luck
Alan
RV-9A N984AW
Old 01-23-2014, 08:37 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
From the wing then up under the upright fuse spar caps then under the fwd canopy deck to behind the panel.
SafeAir sells the blue and green tubing plus fittings in a kit.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
