3m 5200 is a polyurethane base permanent,
Flexible, paintable adhesive. I would not recommend
this product if you think you will ever need to remove
Or seperate what is being bonded.
I have seen cases with wood bonded to fiberglass, completely
distroyed the fiberglass when it was separated, not to mention
the wood. It bonds extremely well to metal. If you scuff and clean
The surface with alcohol, naphtha, lacquer thinner, or acetone. Same as you
would prep for proseal.
I used it on my flap trailing edges, clecoed to a straight work bench, combined with back riveting
On a long steel plate that I bought from harbour freight.
The result was great. Dead nut straight and strong.
This is an alternative to using proseal. It's one part,
cures faster, comes in a small tube for 6 bucks and in my opinion
A better product for the application. Make sure to get the quick cure!
