Old 01-18-2014, 05:57 PM
bobby bobby is offline
Default Flap Aileron Alignment
I'm fitting my flaps, trimming to fit the fuselage and something doesn't look quite right. More still needs to be trimmed for the flaps to fully retract but the trailing edges of the flap and aileron line up now. Once the flap is trimmed to fully retract its trailing edge will be a bit higher than the trailing edge of the aileron. I don't know now by how much but the third photo down shows how much trimming still needs to be done.
According to the plans the aileron is in neutral position in these photos. I also rechecked the wing incidence and it is correct. The flaps do not appear to have any twist.
Any thoughts on this will be greatly appreciated.
Bob Anderson, VAF #2337
RV-8 Flying!!!
Old 01-19-2014, 02:01 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Hi Bob
My suggested sequence:
  1. Fit Wings / Rear Spar attach to final drill
  2. Align Ailerons using tool v outboard rib holes. "Lock" Ailerons using Bellcrank tool
  3. Align Flaps to Ailerons
  4. Fit Fus/Flap Fairings to match Flaps
  5. Fit Wingtips and attempt to align with Aileron/Flap.
  6. If Wingtip fitting not going too well, aim to align Outboard Tip of Wingtip with Aileron/Flap. Then "unzip" some TE of Wingtip, and use the fitting of the Tip Rib and some Resin back in TE to now align Inboard end.
  7. Some creative artistry is now required to bend up the Inboard Flap ends to match the fuselage somehow...
It is a "homebuild" and some of the above will likely not all work to the accuracy of a modern digital protractor Just do your best and hope the (small) errors balance out
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 01-19-2014, 04:08 AM
GLPalinkas's Avatar
What Andy said in #7 is common. After ailerons and flaps are in alignment per Andy's 1-6, most people put a joggle there to match the fuse.
Venice, Fl
Old 01-19-2014, 05:59 AM
cfiidon's Avatar
cfiidon cfiidon is offline
By definition the flaps ARE fully retracted when the aileron is in the neutral position as defined by the tooling holes, and the flap lines up with the aileron.
I think you are trying to get the bottom of the flap to contact the fuselage as is. As posted earlier, trim the flap top surface so the flaps retract to align with the aileron. Then you will cut and bend the bottom of the flap to best "blend" into the fuselage bottom.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 01-19-2014, 06:33 AM
jthocker's Avatar
jthocker jthocker is offline
Originally Posted by Andy Hill View Post
Hi Bob
Andy has posted the most concise process for attaching and aligning the flaps.
The above posters also are spot on, so....... When the inevitable occurs and someone suggests re checking your incidence angle, DISREGARD!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 01-19-2014, 07:46 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
For what it's worth:
I aligned my ailerons using the tooling holes and a bolt fitting snugly into the back of the ailerons. This held the ailerons very firmly. The bar stock was 1/8 x 1 1/4 aluminum from the hardware store...
Then I aligned the flaps to the ailerons, the two shots below are what the inboard end of the flap looked like at this point. I was amazed how big the gap was... It was difficult to neatly bend the inboard lower flap skin to close the gap to the fuselage. Not a great part of the design in my opinion... Unfortunately I did not get a picture of this but there are others on the forum.
Last installed is the top fairing.
This is a shot of someone else's inboard flap bends, neater than mine...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 01-19-2014, 08:02 AM
Thanks to everyone for the replies. On Andy's list I'm on step 3 now and I have completed steps 1 and 2 as he has listed. When I hold the flap fairing in place it also looks like the flap should go up a little. When I fit the wings everything fit very well and the wings needed very little adjustment to get them straight and with the correct incidence. I'll check the flap again for any twist.
Today I'll fit the right flap and see how that one lines up. Yesterday I rechecked both the aileron alignment with the tooling holes and also the wing incidence. They were both correct. When I first set the wing incidence I spent the better part of 10 hours measuring, remeasuring and remeasuring again and again and again. Even with all that initial measuring I was a little nervous measuring it again but it is correct.
Ron - Thanks for the pictures. The last one showing the underside looks like what I'll need to do.
RV-8 Flying!!!
Old 01-19-2014, 10:04 AM
Andy Hill's Avatar
Hi Bob...
The idea, IIRC, is to position the fairing to the flap, not move the flap to where the fairing seems to best fit?
Unless in the newer kits all this is pre-punched (fus & fairing) in which case I can see the issue..?
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Old 01-19-2014, 10:41 AM
Rupester Rupester is offline
Default Adding my testimonial ...
...to Andy's seven-step process. He nailed it.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-20-2014, 08:43 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
For future builders coming to this thread I can vouch for Andy's steps - I built mine in this sequence too(see my log). Andy was the test pilot on my first flights and the aircraft flew wings level stick free
Bob Ellis
www.rv-8.co.uk
G-JBTR Having a ball flying this wonderful machine
Donation July 2016
