Small magnets also
like on a pickup stick work. Make sure the whole assembly comes out, Sometimes I have had only half of it come out. You bleed it by inserting a small blunt wire or screwdriver in the tiny hole on the bottom of the assembly; this pushes a tiny spring valve. If you have an experienced engine guy nearby it is a big help. I think what you called a plunger is the hydraulic lifter. Sorry I don't have a picture.
Dale
ATP, dreamer and maintainer; but not a builder
RV6a N18XP 960TT (builder: Jerry Cochran)
RV6a flight experience 2100 hrs
Superior IO-360 2007
Hartzell Blended Airfoil Prop
Dual LS EI, Dual Battery
GRT HX efis & RAIM GPS, 2 axis GRT autopilot
G696, GDL39 WX, Traffic
Dynon D10
Gear Leg Stiffeners from Woodmanrog
Reason: more info
