Old 01-12-2014, 12:53 PM
Vansrv7arob Vansrv7arob is offline
Default F-792 required if using internal rudder stop?
just wondering if i should bother?
anyone have any photos of finished aircraft with out?
should look pretty nice and clean with out, but the control horn of the rudder obviously still needs to be there so it way more draggy than the F-792s.
So do i need both side of rudder horn or can i cut the right side off to clean it up a bit?
going to use rocket link so chains/springs not required on both sides.
Regards,
Rob.
................__|__
......______(-o-)______
M: (61) 401 578 700
Old 01-13-2014, 12:25 PM
vfrazier's Avatar
vfrazier vfrazier is offline
You can trim the rudder horn, but there's no going back (easily) if you do. On the plus side, I don't think we've ever had a steering link returned because the buyer didn't like the handling. They have been extremely popular.
I have never understood why Van's rudder horns have so much extra "meat" in the vertical plane protruding from the rudder. Seems like it could be trimmed down a bit for less drag. Trim it and add a small teardrop fairing over it.
Has anyone done this? What were your results long term?
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 01-13-2014, 06:02 PM
RV7A Flyer's Avatar
I used the internal stop and no F-792 external stops. Looks very clean...
