Old 02-17-2012, 11:00 AM
KRAUSEGB KRAUSEGB is offline
Default 496 GPS Removal
Is it possible to remove the 496 GPS from the panel without removing the avionics cover piece. I know there is a release on the left side, but it looks like I would have to remove a lot of material from the panel opening in order to get a screwdriver into that release catch.
Anyone have some thoughts on this?
Gary Krause
Old 02-17-2012, 02:30 PM
mv031161's Avatar
mv031161 mv031161 is offline
huh? picture please
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 02-17-2012, 03:41 PM
RatMan RatMan is offline
There should be (IF it was built according to plans) a small hole to the left of the 496 that one would put a tool into, push straight in and the 496 should release from the stock Garmin mount. If there is a hole there, try a welding rod or coat hanger or whatever is stiff enough and small enough to get in there.
If you have access to the plans, look at the page where it was built and you see what I am trying to describe.
John Ratliff
N898R
RV-8
Saucier MS
Old 02-17-2012, 03:53 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Default Remove D180.
Remove the D180. Reach behind the 496 to disconnect wires & assist removal.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 02-17-2012, 03:55 PM
Mich48041 Mich48041 is online now
GPS mounting is on PAGE 42-12 available here:
http://www.vansaircraft.com/pdf/revi...Section_42.pdf
The GPS may or may not be easily removable, depending on the installation.
Joe Gores
Old 02-17-2012, 08:09 PM
Default Thanks
Thanks Guys,
In looking back at my build log, I see that I had circled this step to do later
if I needed to. Now I guess I need to!!
Thanks Again
Old 01-07-2014, 10:04 AM
Paris12Man's Avatar
Paris12Man Paris12Man is offline
Default First time removal
I'm trying to remove my GPS 496 from the panel to update the unit and I'm unable to remove it from the docking device. I've looked over installation pages 42-12 and 42-13 to refresh my memory of what it looks like behind the panel.
So at this point I've removed the D-180 and can somewhat get my hand behind the 496. Do you push the release clip in from the front side and at the same time push a rod through an open hole in the backside brace pushing the unit out? I can't believe this is the process!
For those of you who have removed the 496 from the panel, I await your suggestions. Thanks
Steve Garrett - 903-272-5639, scg3037@icloud.com
N905RV - 520 hrs to date
Home field XS30
Old 01-07-2014, 11:26 AM
There is a sliding lock on the hook that must be slid toward the nose of the aircraft. Then you can pull the catch arm away from the GPS an pop it loose. I didn't set mine up for removal from the front, and the last time I removed it (about a week ago) I puzzled over how you get it out if you didn't enlarge the opening. I ended up removing the whole cradle to get it out.
I disconnected the XM antenna and plugged in a USB cable that I ran through the avionics bay deck. I wasn't using the XM anyway, so it was no issue. Now I can update without removing the unit. The cable is velcroed to the deck bottom near the POH tray when not in use.
Old 01-07-2014, 11:53 AM
Dave12 Dave12 is offline
Slide a pick in the small hole to the left of the unit and push inward and if you clearanced the unit sufficiently during the installation, it should pop out. As I recall, I did spend a fair bit of time making sure the unit would come out for me without removing anything else. I would think that removing the D180 or the AP74 would enable you to get it out.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 01-07-2014, 02:53 PM
Paris12Man's Avatar
Default Thanks guys
I've tried everything I can think of to remove the unit but no luck. I can release the lock on the left (pushing a rod through the small hole) but I just don't have enough clearance around the unit for it to come out one edge at a time. Soooooooo, (I didn't want to) I'm going to take the top of the instrument bay off and access in that fashion. I can guaranty you the next time the unit has to be updated, it will easily come out of the panel or I'll have an external connection port.
Thanks for the suggestions. Steve
Home field XS30
