  #11
Old 01-05-2014, 09:38 AM
jdiehl jdiehl is offline
Default getting started
My 12 yr old son and I went to Oshkosh (10 yr ago), attended the "metal working 101 class' multiple days, swung by Avery and bought the RV kit, headed home and placed the order for the empennage. Eight years later, we were the proud owner of a flying 7A. We had NO building experience going into this project and NO hands-on experience (other than the Oshkosh builders seminar). Take your time, understand the plans, think before you perform a task, and all will go well. Also, I stole shamelessly from the many builders logs that provided invaluable resources. And, of course, this site was utilized nearly every day. One downside we experienced was not having any other builders in this part of Pa. Countless hours would have been saved if I had a completed RV to look when questions arose.
Jim Diehl 7A
Lock Haven, Pa.
Old 01-05-2014, 09:57 AM
Captain_John's Avatar
Originally Posted by PilotRPI View Post
I'm thinking about jumping into an RV7 kit. I really wanted to do the EAA RV class, but just missed the one in Boston. They seem to come around every 18 months or so. I'd rather not wait that long before starting.
So my choices are:
1) Get both of the RV practice projects, and try and make as many mistakes there as possible. Learn by reading the manual, watching youtube and EAA videos, etc.
2) Fly somewhere to take the EAA class
Almost all these skills would be new to me. I consider myself handy and technical. I can teach myself how to do jobs on my car, I have an aero and mechanical engineering degree, I've done some shop work, pulled an airplane engine apart, etc, but never done things like parts prep and aluminum construction.
I know the EAA class if worth it if it is local, but do you think its worth taking a small vacation to do it?
Also, has anyone on here done a poll of how old people are when they complete their first RV?
Thanks!
Jesse
Jesse, Come down to Plymouth and have a look at my project. We can talk about RV's, buck some rivets and what not.
Shoot me a PM and I can give you directions to my house.
CJ
The experiment works!
Old 01-05-2014, 10:29 AM
bret's Avatar
bret bret is offline
One thing not mentioned yet, is the comprehension of the plans, the emp kit, you are walked through step by step, when you get to the fuse kit, you need to spend a lot of time looking at the plans. The book O instructions will not say This then that, you need to identify every detail on those drawings and some way of documenting a check off list. Then there's wiring and plumbing
Old 01-05-2014, 10:38 AM
diamond diamond is offline
I flew half way across the country to take the EAA Vans course and am glad I did. The only regret/suggestion I have is that you wait to take the course when you are ready to begin building. When I took it, I wasn't even sure which aircraft I wanted to build and now here I am 3 years after the class just starting to build (life happens). I feel rusty on the skills I learned, but am confident I will hone my skills quickly.
Old 01-05-2014, 12:07 PM
60av8tor 60av8tor is offline
Originally Posted by rzbill View Post
I was talking to a prospective builder in my hangar earlier in the week and he said he was going to a builder class in Frederick Md very very soon. Maybe you could check to see if there is an open seat?
I'm attending this class - 18-19 Jan. I definitely believe it will be worth the time and $$. I was initially scheduled for the general sheet metal workshop over the same weekend quite a bit closer in Lakeland, FL, but decided to make the drive for the RV specific class. Whether that was necessary - who knows.
Knowing local builders is definitely where it is at, but I believe this will be time well spent. Have the shop ready and tools on the way. The class and a couple practice kits, and then it begins.
Jon
Old 01-05-2014, 04:10 PM
PilotRPI PilotRPI is offline
Thanks everyone. I think I will order the preview plans, then hang out with a few local builders I've met. If I get the hang of things, maybe I'll do the practice kits and order the tail from there.
If I feel a tad overwhelmed, I may try and take one of the classes.
Jesse
Old 01-05-2014, 04:43 PM
aparchment's Avatar
aparchment aparchment is offline
Default Learning
Hey Jesse,
I took a class and the best thing that it did for me was show me that it's really not that hard to build a metal airplane. As one of the guys said above, the key isn't learning the skills, particularly if you are already handy, it's sticking to the project until you finish it. That sounds pretty easy to do, but along the way life may throw you a few curve balls that you will need to overcome in order to keep going.
Take CJ up on his invite, and if you feel like trecking north, come visit me. John is quite a bit further along than I am and up to his neck in wiring, so that may seem a little intimidating/overwhelming. The plans too may seem a little overwhelming if you have never worked from a set of blueprints before. Look at it as building a bunch of components that at some point get assembled into a finished plane. If you look at it as manageable smaller projects it is less intimidating.
The keys to success are 1) resources (60-100K depending on equipment), 2) time to build and 3) will to finish.
Antony
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 01-05-2014, 05:40 PM
aeroaddict's Avatar
aeroaddict aeroaddict is offline
Talking Go for it
I'm in a similar situation as I have just purchased a partially completed kit. I was not planning on this approach but it was local, good quality and a fair price. My original plan was to build from 'ground zero' after taking a class; either EAA or Synergy.
I are () engineer and worked in aerospace my whole career. While I never drilled a hole or pounded any rivets at work, I'm very comfortable around sheet metal and blueprints. I did attend Airventure this year and took the mini sheet metal basics class.
After going back thru the previous builders work to verify completeness and quality I plan on starting where the previous owner left off. I ordered the Vans training project to help learn the tools, but after that I have no issues with starting where he left off.
I say you will be fine, take your time and figure it out.
Old 01-05-2014, 06:30 PM
Norman CYYJ Norman CYYJ is offline
Before you start making anything get the preview plans, then read it from cover to cover carefully. This will give you the big picture of what you will be doing and you will be better able to understand what you are doing. It might even prevent you from riveting yourself into a corner.
Old 01-18-2014, 04:48 PM
bartelsb bartelsb is offline
Smile Deciding to build
So last June, I flew to Portland OR on a cheap Jet Blue flight and spent a day in Aurora at Vans Aircraft.
I had a personal expert assigned to me and we talked specifically about motivations, time, flying ability, planned reasons for flying. Building skills and building facilities.
Although I had not asked for a demo flight, I accepted one in a sliding canopy RV-9 with a IO320 and fixed pitch prop. NICE!!!
Believe it or not, I came away from the trip knowing that I was going to buy a completed aircraft, and not to buid one. Vans offered to do a prepurchase anywhere in the country.($$)
I lurked in the wings looking for RV's. Then one day in November an RV-3 came up at my own field. INSTANT gratification.
I have not looked back. N833RV Vans RV-3 is just a beautiful specimen of what a good build should look like.
