View Poll Results: Do You Check/Pump Brakes Before Landing
Yes 61 34.08%
No 91 50.84%
Sometimes, but not a habit 27 15.08%
Voters: 179. You may not vote on this poll
  #41
Old 12-18-2013, 11:32 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by Toobuilder View Post
Absolutely agree. The tap on the brakes is just an assurance that things are normal - just like seeing "three greens" on a retractable.
Checking the brakes adds a fraction of a second to the process of making sure your feet are where they're supposed to be and you have free movement of the pedals. Which I do, and is actually more important than a brake check.
With the criticality of brakes at landing, assuming nothing happened during flight is not enough of a driver to pass up the opportunity to check. I also check free and correct flight controls three times before takeoff (start up, run up, entering the runway - overkill, but I can still forget twice and get it done).
And yes, I am speaking about brakes and rudder pedals from a conventional landing gear perspective. The difference in criticality is huge.
Old 12-18-2013, 11:44 AM
Just a guess, but I'd think that the majority of the people who check their brakes before landing fly taildraggers and the pilots who don't fly nose-wheel aircraft.
Dave
Old 12-18-2013, 12:07 PM
TangoPapa's Avatar
TangoPapa TangoPapa is offline
If you don't you should. Wouldn't it be nice to find out there is a problem with your brakes before you need them. I've had water get in the brakes and freeze, So remember Sh#$ happens and it best to figure it out sooner than later.
I'M NOT SPEEDING...I'M QUALIFYING.
Terry Peterson
Old 12-18-2013, 12:29 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Brakes
I'm probably in the minority here.
I was taught from day 1 to apply pedal in pre-start checklist & the again after starting to taxi. An anomalies should be checked on the ground...duh.
I agree with Walt, if they worked up to last T.O. then I'm OK with that.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 12-18-2013, 06:19 PM
60av8tor 60av8tor is offline
You are joined by many 172 pilots - checklist item during run up.
Jon
