  #11
Old 12-17-2013, 07:46 PM
SteinAir SteinAir is offline
There are also a few other things to consider...for example your IFR or VFR static / transponder checks, if you have a certified prop then maintenance on that (or a few other things) if you desire for it to remain certified (which goes back to your original airworthiness app and the 25/40 hr flyoff), instrument repairs on certain things, and possibly some acessories. So while most posts are for the most part technically correct, there are still other things to consider!
Just my 2 centas as usual.
Stein
Old 12-17-2013, 08:25 PM
N941WR's Avatar
N941WR N941WR is offline
There is a great deal of difference between an annual ?Condition Inspection? for an E-AB and an ?Annual Inspection? required for a ?certified? airplane such as a Cessna 172.
(Mel, correct me, if I?m wrong.)
A ?Condition Inspection? can be signed off by an A&P, no IA required. The purpose of the ?Condition Inspection? is to make sure the aircraft is in a condition for safe flight. Thus, if you remake your instrument panel, change an engine, change your prop or whatever, the A&P simply makes sure the airplane is safe.
An ?Annual Inspection? must be signed off by an IA. That signature indicates the aircraft conforms to a ?type certificate? and any additional 337 or approved modifications.
Check your ?Operating Limitations? for details.
Also, a ?Repairman Certificate? is another license, similar to an A&P license, issued by the FAA. It is given to the one person the FAA determines built a particular Experimental ? Amateur Built. That license allows the builder to continue to maintain it. For example, if you and I built identical airplanes, side-by-side, you could get the ?Repairman Certificate? for your plane and I could get one for my plane. You could sign off your plane?s Condition Inspection but not mine.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-17-2013, 08:36 PM
Mel's Avatar
Mel Mel is online now
Default Yes. Except for one minor point.
Originally Posted by N941WR View Post
There is a great deal of difference between an annual “Condition Inspection” for an E-AB and an “Annual Inspection” required for a “certified” airplane such as a Cessna 172.
(Mel, correct me, if I’m wrong.)
A “Condition Inspection” can be signed off by an A&P, no IA required. The purpose of the “Condition Inspection” is to make sure the aircraft is in a condition for safe flight. Thus, if you remake your instrument panel, change an engine, change your prop or whatever, the A&P simply makes sure the airplane is safe.
An “Annual Inspection” must be signed off by an IA. That signature indicates the aircraft conforms to a “type certificate” and any additional 337 or approved modifications.
Check your “Operating Limitations” for details.
Also, a “Repairman Certificate” is another license, similar to an A&P license, issued by the FAA. It is given to the one person the FAA determines built a particular Experimental – Amateur Built. That license allows the builder to continue to maintain it. For example, if you and I built identical airplanes, side-by-side, you could get the “Repairman Certificate” for your plane and I could get one for my plane. You could sign off your plane’s Condition Inspection but not mine.
Anyone can maintain the aircraft. The repairman certificate relates ONLY to the condition inspection.
I know what you meant to say, but the wording is important to others reading this.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-17-2013, 08:40 PM
flightlogic's Avatar
Can I return to the seller (builder with a repair cert. on the plane) each year and have him sign a conditional.... even though he no longer owns it?
He said he would love to see it and take a ride now and then....
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 12-17-2013, 08:47 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You can absolutely have him sign off the CONDITION inspection. I have no idea what a "Conditional" inspection is....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-17-2013, 08:50 PM
An ?Annual Inspection? must be signed off by an IA. That signature indicates the aircraft conforms to a ?type certificate?....
There is no way an IA will have access to the specific engineering data which defines conformity to a type certificate. And I don't think there is any requirement that the aircraft be inspected to that specific standard.
Dave
Old 12-17-2013, 09:16 PM
rvbuilder2002's Avatar
Since Mel didn't entirely answer your question...
The standard is actually the same. Both inspections are to be completed in accordance with the scope and detail of AC43 appendix D. The reason that stipulation is in E-AB operating limitations is because of the fact that FAR 43 doesn't apply to Experimentals (stated in the very first paragraph of that Part), so the inspection standard requirement has to be written back in via the operating limitations.
The main difference is the level of certification required to do the inspection. For certificated aircraft, that is also stipulated in FAR 43. Since FAR 43 doesn't apply to experimentals, that is why the operating limitations also have to stipulate who can do the condition inspection.
Scott McDaniels
Hubbard, Oregon
Old 12-17-2013, 09:24 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Dave
As always, the FAA does have a standard... part of it says -
The aircraft should conform to the aircraft specification or type certificate data sheet, any changes by supplemental type certificates, and/or its properly altered condition. When the aircraft does not conform, use the procedures for “unairworthy” items listed in 14 CFR part 43, § 43.11(a)(5).
The document is here -
http://www.faa.gov/training_testing/...-g-8082-19.pdf
To rvbuilder2002 comment, while the airworthiness inspection may be the same for certified vs. experimental (Part 43, Appendix D), the standards are different if the inspector finds parts he deems to be not in the original aircraft specification. A wally mart part may be deemed airworthy and approved for an experimental, but if found in a critical location on a certified plane the IA is instructed to fail the inspection, or possibly create a 337 to authorize it.
If this wasn't the case, my Tiger would now be flying around with a nice Skyview system in it's panel...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-17-2013, 09:51 PM
nauga nauga is offline
Oh man, talk about geek-bait
work = months > 12 ? inspect:fly
Nauga
2004 RV-4
Old 12-17-2013, 11:17 PM
rvmills's Avatar
rvmills rvmills is offline
Bill, just a little semantic fun (sort of), but calling a Repairman Cert similar to an A&P mayyyyyyy be a bit of a stretch. Don't get me wrong, its takes incredible effort to get each, and I have great respect for both, but the scope of requirements to obtain each, and the scope of authorizations each grants, is quite different. In fairness, you touched on that a bit. The painful similarity to me is that...I have neither (need to work on that!)
One thing for Tram to consider (I don't think its been mentioned) is that you can do much, or most of the work on your condition inspection…it just needs to be signed off by an A&P. Prudence dictates that you work within your limitations, and under the watchful eye of the A&P (he'll likely require that)…but its a great way to get to know your airplane, and learn from a shmart guy in the process. I'm doing that very thing right now…I'm the labor, he's the brains. I learn, he earns (deservedly so!)
I do wish that if you have rebuilt 51% or more of your plane that you could earn a transfer of the Repairman's Certificate…but I know it aint gonna happen!
Well, I guess who can do the inspection annually, to determine the Airworthy Condition of the aircraft, is Conditional upon what certificates one holds, conditionally speaking!
What deep secrets is Nauga-hyding within that formula!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
