  #21
Old 12-11-2013, 05:22 AM
catmandu's Avatar
catmandu catmandu is offline
Originally Posted by Walt View Post
Funny.. no diesel, without the kerosene heater running I can't feel my hands!
This weather is just not right for Texas!
OH, MY, GAWD!
Kero in a yellow container? Guvmint man gonna git you!
(I've actually had people chastise me about color vs. product at the pump.)
Mike C.
Sierra Nevada
RV-6A bought flying
Old 12-11-2013, 05:37 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by Mark Dickens View Post
My understanding was that AN fittings were to be installed with dry threads...I take it that I am misinformed?
The PIPE threads (and only the pipe threads) must be sealed (I generally use tite-seal). The flares, B nuts etc. go together dry.
Originally Posted by catmandu View Post
OH, MY, GAWD!
Walmart had them on sale
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-11-2013, 05:40 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Sorry for the multiple posts. I kept getting a "database error" and thought the response wasn't posting...
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 12-11-2013, 05:43 AM
pierre smith's Avatar
Default Wow!
Fuel in the tunnel of a -10 is an explosion waiting to happen.....unfortunately for one gentleman on here, already has.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-11-2013, 05:57 AM
rocketbob's Avatar
Hi Walt. Not to hijack the subject but you are a great RV anatomist what's that extra port on stock Vans selector for? Can I plumb aux cabin tank into it?
Vlad is that sealant I see on the B-nuts? If so that's a no-no.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-11-2013, 06:09 AM
Wayne Gillispie Wayne Gillispie is offline
Well, it does say EZ Turn, making threaded connections easier to turn. Just kidding. One must have thick skin to post pics on the net.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 12-11-2013, 06:20 AM
Walt's Avatar
Originally Posted by TS Flightlines View Post
Gee Walt----great catch. Thank you for taking pics for everyone to see.
This get serious in a BIG hurry.
Tom
FYI: Tom is making me a full set of FWF teflon firesleeved lines to replace the homade ones, I'm a big believer is letting the pro's do what they do best and Tom is a pro at making lines!
I would suggest everyone do the same unless you have the proper tools/materials/training to do it properly.
Old 12-11-2013, 06:22 AM
Thanks RocketBob for looking over it.
It's a bit of EZturn on threads only flares installed dry. Every one hundred hours I inspect fuel lines the only seep was found at a gascolator fitting.
Old 12-11-2013, 07:43 AM
HSANTIBANEZ HSANTIBANEZ is offline
I hate when I find this stuff, it's a lot of work to fix
All this stuff in the tunnel of a 10
Leak at fuel selector
Leak at feedthru from tank L/H side (notice the blue staining on insulation)
Leak at fuel pump 'T'
Making your own FWF hoses? Maximum gap allowed between nut and collar is 1/16" (this one is over a 1/4")
If your flares look like either one of these you've got more work to do!
Quick tutorial on flaring. One of the more important things is lubricating the cone before starting the process, if you don't you will "smear" the metal in the flare.
http://www.sportaviationonline.org/s...01/?pg=80#pg80
Dear Walt, did you have fuel smell in the cockpit?
Regards,
Hern?n Santib??ez
Valpara?so, Chile
RV-7 TMX-IO-360 G3X and VPX Flying over Chile
2018 Dues Paid
Old 12-11-2013, 08:30 AM
sahrens's Avatar
sahrens sahrens is offline
Default TS Flightlines
This exactly why I went with Tom to fabricate teflon lines for the fuel lines from tank to selector valve and selector valve to fuel pump. More expensive, but after critically reviewing MY flares it was an easy decisiion.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
