12-08-2013, 11:23 AM
I have a Kat's 24150 150W installed on my superior 180, heats the oil in 15-20min and easily glues to the oil case, on since 2009. I don't leave it on only plug it in a before flight. As good as th reif but only about $30.
http://www.northerntool.com/shop/too...9139_200339139
Bob Eggleston
12-08-2013, 11:54 AM
What you want to do is warm the engine, not just the oil. As soon as that 120F oil flows through that 20F engine, you're going to have 25F oil and a 25F engine. 150 watts needs an hour (preferably 2-3-4 hours), cowl plugs, and a blanket over the top to make a big difference in preheating an engine.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
12-08-2013, 01:05 PM
I heat the sump with my Kat
I think Kyle is right; the cold engine will cool the oil quickly but it is my belief that the warm oil is easier for the pump move immediately after starting. At least the innards of the engine get lubed sooner with preheated oil.
I have my 6 in a insulated hangar so have no real experience starting it in very cold temps. But the 0-300 powered 172 that I used to own was kept outdoors for awhile and believe me it's a gut wrenching 5 seconds or so waiting for the oil pressure to show signs of life on those rare occasions when pre heat was not available. With preheat the pressure came up immediately in even the coldest wx, which led me to believe that even heating the sump is better than no heat at all. IIRC the Continental manual said to wait 30 secs. for oil pressure and to preheat when temps got below 20F.
My Kat heater works great. I do not leave it on unattended though and after an hour on a 32F day my oil temps are 50F immediately after start. I bought two of the 150w pads but the other one fell off my truck and was dangling by the cord. It still heats though. So I'm looking for a good glue and thinking of attaching it next to the other one on the sump.
Jim Woolard C56
N9855J RV-6 Donated 2020
12-08-2013, 01:38 PM
These are aluminum engines - very high thermal conductivity. Warm oil eventually means a warm engine even with zero oil circulation. A few hours on the oil sump heater and the cylinders are warm to the touch.
It's not rocket science.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
12-08-2013, 04:55 PM
Cost
As a side note to the cost difference of an aviation rated heater and one for the local auto supply store: I set up a search notification on eBay so whenever one was listed, I was notified. I purchased both of mine brand new in the package for less that half retail. Took a while to get theme at the price I wanted to pay, but in the summer, most folks aren't thinking about pre-heating their engines.
David C.
Howell, MI
12-08-2013, 05:25 PM
Nice pun!
Thanks for the price watch, ordered one today.
Mike C.
Sierra Nevada
RV-6A bought flying
12-08-2013, 06:07 PM
Reiff Oil Pan and Cylinder Bands
I am in an un-heated metal hanger with no insulation. It is as cold inside my hanger as it is outside. The only thing that the hanger does is protect me from the elements. I use the Reiff system that has both the oil sump heater and the cylinder bands. I keep an old blanket draped over the cowl. It is amazing how much heat is under the blanket and in the engine compartment. I keep my unit plugged in and turned on from the time I put it back into the hanger until I pull it back out to fly again. (During winter months) I also have a ceramic heater that I put in the cabin of the plane to warm up the interior and instruments. I have steam gages. I turn on the ceramic heater an hour or two before I fly.
When I get my RV finished it will have the Reiff system it. We finally broke back into the double digits for temp this afternoon, but it is snowing. Tomorrow will be a no fly day but a plow the airport day.
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
12-08-2013, 06:23 PM
Bob, I see the northern tool specs say it is not thermostatic controlled, but the same Kat model from Amazon says it is thermo controlled. Can you help with this answer?
Bill
RV-7
Lord Kelvin:
12-08-2013, 06:45 PM
I have 2 of these Kat models and they are straight plug, no thermostat. This company makes several models of these, so it's possible one will have a thermostat, but not these.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
12-08-2013, 07:54 PM
lots of options...
if you only need it occasionally there are lots options
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
