Old 12-07-2013, 01:21 PM
mvidalr's Avatar
mvidalr mvidalr is offline
Default Wingtip light reflector
Hello,
Does anyone know if it is possible to purchase a couple of aluminum mirror-like/reflectors cut and bent to shape that will go inside the W-715-1 wingtip light housing?
I am planning on installing AeroLEDs Pulsar NS nav/strobes, but don't want to install them directly on the fiberglass surface, and don't like the looks of plain -or otherwise painted- fiberglass all by itself.
Here's a picture of what I need:
thanks
Miguel Vidal
EAA #1133587
RV-8 SB Wings in Monterrey, Mexico
N511MV Registered
MyKitLog
Old 12-07-2013, 01:35 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default DIY
I just traced the shape, cut the shape out of some aluminium stock and polished it up and added some nut-plates so that it can be removed.
Didn't take all that long to do it either,.
DP
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 12-07-2013, 03:09 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
I have seen this done with red on one side and green on the other. Try this:
http://www.professionalplastics.com/ACRYLICMIRROR
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 12-07-2013, 03:24 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Did mine with .016 stainless. I did not polish it, but it would probably look nice if you did... Make a card template first... The fasteners for the lights hold it in place.
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 12-07-2013, 03:26 PM
rapid_ascent rapid_ascent is offline
I bought some of the reflective acrylic for mine. I'm building the lights using LEDs so I needed some thinner material that I bought at professional plastics. There is a minimum lot buy though so that makes it more expensive. If you still with the 1/8" material you can find it around, maybe even Home Depot.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-07-2013, 04:52 PM
mvidalr's Avatar
Default the DIY way
Thanks guys.
I appreciate you all's inputs. I used the template-and-cut-to-shape acrylic mirror method before posting, but thought there might be other "professional" (i.e. purchased) ways of doing this.
I used the cheap Wal-Mart cut-to-shape CIPA Replacement Mirror (http://www.walmart.com/ip/CIPA-Cut-a...irror/22614764), and really liked my results for a $7 piece of shiny plastic. Had to think about some considerations like strength, heat dissipation, ease of handling, and aesthetics, in that order, but so far it seems it will do the trick.
We'll see how they withstand the heat after several hours of operation (although I'm using AeroLEDs which are, theoretically, cooler).
Thanks again.
Miguel Vidal
EAA #1133587
N511MV Registered
MyKitLog
Old 12-10-2013, 04:46 PM
n82rb's Avatar
n82rb n82rb is offline
chrome stick on monokote trim from the hobby shop. mines been on for 10 years and is still sticking and shiny.
bob burns
RV-4 N82RB
