Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 12-04-2013, 06:09 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Unless you plan on going high and LOP, then injection is not going to give you much economy over a carb.
Steve and Michael, there is some crazy misbelief that you have to be high and low power to run LOP. This is simply not true.
Steve for low level work, I will climb to say 1000-2000' WOT, pull the RPM back and do a Big Mixture Pull, and it is really easy when you know a fuel flow to aim for, but a BMP parks you safely LOP at 80+% HP, so why not.
Yes you can run carb engines LOP, and the O-320 is a fine example, but generally speaking the IO version is better on both the Rich side and Lean side of peak.
I have posted this before, so many here will be sick of seeing it, but you might gain something from it.
As for starting problems or anything else??the IO system is better. I noticed Smokey Ray had some comments about swing starting in the outback?.not sure about that, I do not swing start in the city either
My colleagues at APS know a thing or two about engines, one here in Australia is the countries leading engine builder and engineer. 25+ years in the industry, and I can assure you my comments are in harmony with theirs. I am not a fan of consensus of opinion, sometimes it is applicable but here the facts are what they are. It is up to you armed with the info supplied.
Concensus is 99 people all holding the same opinion, until one person comes along with data that blows the hypothesis. Now you have a 1% majority rule .
David Brown
Old 12-04-2013, 06:39 PM
Toobuilder's Avatar
Originally Posted by RV10inOz View Post
Steve and Michael, there is some crazy misbelief that you have to be high and low power to run LOP. This is simply not true...
My point about being high was not as a "condition" for running LOP. I run LOP down low all the time. My point was that I do serious cross country work and I'm up high to gain the TAS benefit and cover some ground. And long cross country flying is where you are going to gain the most benefit (economy) from a fuel injected engine. "High and LOP" was a characterization of the mission and meant to contrast with Sunday morning breakfast runs or pattern work, that's all.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-04-2013, 07:50 PM
Beancounter Beancounter is offline
Default fuel savings
I am running an o-320 with 9:1 pistons. I run 10-12 LOP consistently with about a 6-8 degree CHT spread without carb heat. Any leaner and its gets rough. If I were to convert to FI and able to run 20 LOP with CHT's within a few degrees of each other, how much less fuel burn could I expect. For example if peak to 10 LOP is .5gph, would 10 LOP to 20 LOP also be .5gph or does the curve drop off significantly above 10 LOP.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 12-04-2013, 08:32 PM
RV10inOz's Avatar
You are proof like some I fly here, that the O320 is a nice LOP performer. It is a great little engine.
Notwithstanding and I have also a bit of experience with an IO320??it is better overall, because it is easier to operate that way and smoother, because the spread was far better than the 0.5GPH.
There is no gain in running excessively LOP, you actually become less efficient eventually. Refer to the 1/BSFC curve below, courtesy of Adv Pilot Seminars
David Brown
Old 12-07-2013, 12:45 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Hi Steve..
Echoing the above, Alister and I have an O-360 and IO-360 between us, and have moved from Mags to single P-Mags to Dual P-Mags. As you say, UK flying tends to be lower level, say 2000'. Summary:
  1. LOP is (far) easier with the IO. However, Alister manages it with a Carb, but harder work / more limiting on settings.
  2. It is, IMHO, essential to have 4x EGT and pref 4x CHT
  3. The biggest leap in ease of LOP is Electronic Ignition. I do not think you need a "good" EI, I would suggest they are all good and essentially do the same.
  4. 2x P-Mag is a little better than 1x P-Mag
  5. Maybe due practice, I find LOP easier at the lower levels.
  6. 150KTAS on 25L/hr [6.6USG] is standard (RV-8). I would hope an RV-4 would be better?
David's graph sums it up - you only want to be just LOP. With Mags it is quite hard to go far LOP, I found it got rough. With EI it will run fine very LOP - it just goes slowly
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 12-07-2013, 02:27 AM
WAM120RV WAM120RV is offline
Default LOP
Hi ALL
Again thanks for the replies. I actually run a Lightspeed ignition and one mag. I have EGT/CHT on all 4 cylinders.
Having read all these replies and considered my current flying in the 4 I doubt I really have a problem. As I am breaking in the engine and have to keep the power up and temperatures down I have been reluctant to lean aggressively.
When I have leaned it it has been rich of peak again to keep temps down.
Now, all my T's and P's have been well in the green, my home built plenum is working fine. So, I will try some L of P operations and note the temps and see what fuel burn I get then.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 12-07-2013, 06:44 AM
RV10inOz's Avatar
If you are breaking in, it is better to do it LOP.
1500' WOT, 2500-2700 RPM and 80dF LOP.
This gives you MUCH BETTER breakneck by better BMEP, with lower overall ICP and CHT.
Exactly opposite to popular myth.
David Brown
Old 12-07-2013, 07:38 AM
dealfair dealfair is offline
Hi Steve,
I ditto what Andy said. I have an O-320 w/dual P-mags and a Dynon D-180 for engine monitoring. For years I heard all sorts of horror stories about running LOP and was reluctant to even try it.
I believe I've read everything possible about LOP operations. I saw and read David "Shot Duck" Brown's chart and decided to try the BMP and see what happens. Well, I was favorably rewarded. For a carburetor, my spread is pretty good. Generally, running somewhere from 5* to a max 20* LOP I can get 130 +/- knots at 5.2 to 5.5 gph. (Any more than 20* its rough.) I was/am shocked at the numbers and didn't believe them at first. But I do this on a regular basis now. If I'm up just smashing bugs or not in a hurry, well I now use fuel flow for my power management plan. It saves me a good $10.00 to $14.00/hr.
A good buddy of mine has a Flight Design CLT w/Rotax 912 and does about the same, maybe burning a little more. That's a wonderful comparison I'm thinking.
I'd love to have Fuel Injection; but running LOP regardless has been a pleasant surprise to me. So thanks to David and others for getting me to give it a try. Count me in the LOP camp now.
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 12-07-2013, 10:48 AM
jay bell jay bell is offline
Talking Saving fuel
Hi Steve
I have an ECI IO 375 with Precision FI, dual Slick mags, and a coarse, fixed pitch prop on my 7A with 120 hours TTSN. This is my first injected engine, and until I learned how to start it (my procedure and results are similar to Russ's description), I considered swapping it for a carburetor. I get the same consumption and performance numbers as Russ (although I have to confess my speeds are in MPH, not knots). My flying is a mixture of 3-4 hour cross country legs around 10,000', and short hops to neighboring strips.
Even though I (now) like my FI engine, and will get another if the opportunity arises, I would not change a carb to FI on a flying aircraft as the cost and time to change two fuel pumps, fuel line plumbing, intake manifold, cowl, and possibly throttle, mixture, and exhaust will suck up time and money better spent on flying.
I am also very conscious of fuel costs, and recommend the following to maximize the efficiency of these excellent planes:
-Slow Down. Most RV'ers cruise well above the best range power setting. I typically set power at 50% for long distance and local flights following climb or takeoff. According to my EFIS, my economy tops out at 30 mpg at about 40% LOP, however the plane feels better at a 50% power setting which yields 28 mpg. (avoid continuous low power settings until your engine is completely broke in) My hanger neighbor has a Rocket, and jokingly complained it is hard to build time on the machine because it gets everywhere so darn quick!
-Lean aggressively by ear at low power settings. Your engine does not care about altitude, only manifold pressure. For short hops I take off with full power ROP, reduce throttle to 60% power at 1000', lean until the onset of roughness, then enrich until roughness goes away. This results in happy engine monitor readings, and about 50% power at 7.0 gph. I can fine tune the power down to about 6 gph if I care to fly as slow as a Cessna 182.
-Try running premium automotive fuel if possible in your circumstances. I am a believer in mogas, and would run some even if it were the same price as avgas. With my compression ratio I run straight avgas in one tank for take off, and also to manage the risk of vapor locking I experience on mogas in warm weather with just the engine driven fuel pump running. In my area, mogas runs about 2/3 the cost of 100LL, and it is better for spark plugs, valve train, and the environment.
-Consider one of the electronic ignitions which save fuel by advancing ignition timing at low power settings, and also by providing a better spark which allows your engine to run leaner before the onset of roughness. I researched 5 good systems and spoke to owners to determine the system I like best, and have this as my next planned upgrade
